Question about Toro Lawn Mower With Toro Power Tools
Toro GT5 lawnmower - the pull cord (to start the engine) only comes out about 3 inches - I'm afraid to pull to hard for fear of breaking the line.
  • 903 Answers
The drive shaft probably just needs to be lubricated. Squirt some WD-40 or oil onto the shaft where it disappears into the body of the mower. Then turn the blade by hand a couple of times and squirt some more in, and repeat until the blade becomes easier to turn. Then the cord should pull without a problem.
Posted on Aug 27, 2010
    Problem Solver:
  • 5 Answers
First of all disconnect the spark plug wire. Then turn the awnmower on it's side with the carburetor pointing up. Carefully try to turn the engine using the blade, you should wear gloves as to not cut yourself on the blade. If the blade will turn a full revolution 360 degrees you should check your recoil starter for a foreign object jamming it. If the engine only turns a little bit or not at all there is a good chance the engine was run without or low on oil and it is siezed.
Posted on Sep 16, 2009
    New Friend:
  • 93 Answers
You will have to pull hard at least once to settle this problem. Are you sure you sure you do not have the engine brake engaged? If this mower has a brake relese (engine), YOU MUST PULL BACK ON THE LEVER AT THE TOP OF YOUR MOWER. iF THATS NOT IT we NEED MORE INFORMATION !
Posted on Sep 15, 2009
    Genius:
  • 1,036 Answers
First - remove spark plug and squirt 3mls of engine oil in there - replace spark plug and leave overnight.
Try pulling that start handle !
Two things may happen - it snaps or - it turns over.
If it turns over - prime fuel and start in choke setting.
If the cord snaps - undo the pull start block - and take it to a lawnmower spares depot, and buy some more cord. It's quite cheap.
Get the length right so you don't have too much.
Next - the engine is probably seized - so needs freeing up. You may be able to do this with the new cord, Otherwise - take the head off the cylinder and tap the piston down with a wooden drift while turning the crank.
Use a non-setting gasket sealant like hematite red to re-use the old gasket. Lawnmowers are quite resilient.
Posted on Aug 11, 2009
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
Gas leaking from muffler
Blown engine. Replace engine.
Jun 17, 2012 | Toro Power Lawn Mower
10 year old Toro 2017 lawnmower, suddenly stopped while cutting grass. Oil quite low. Cannot pull cord more l than few inches.
When you pull the cord does it hit a hard stop and not go any further or does it get really difficult?
Aug 02, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro Personal Pace Recycler mower with a 6.0 hp GTS engine. I need help on replacing the pull cord.
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Oct 02, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 200-43 name sr-21s serial # 200012530 pulls hard to start but won't start pulled spark plug still pulls hard and no spark
Sounds like the engine stop cable has stretched or broken and is not releasing the engine brake. This cable also disengages the kill switch to the ignition module. Follow the cable from the upper handle down to the side of the engine and watch how far it will move the brake lever. If it is less than 3/4 of an inch, the cable will need to be replaced.
Sep 06, 2010 | Toro Lawn Mower With Toro Power Tools
Lawnmower wont start
check your sparkplug clean or replace, also crank it several times without sparkplug in it to blow out the cylinder, did you have it on it's side for anything?
Jun 05, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My toro lawnmower (brand new) it doesn't start.\r\...
The drive shaft might just need to be oiled. Turn the mower over and locate the drive shaft, where it goes from the mower's blade up into the body of the mower. Lubricate the area of the shaft that disappears into the body with WD-40 or another lubricant, then turn the blade by hand (be careful!) and squirt some more oil.
Eventually the blade should become easier to turn, and then your pull cord should extend without getting stuck. Good luck!
May 20, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 lawnmower wont start when you pull the cord it comes out about an inch then it locks where you cant pull it no more
Remove the plug then try and see if you can pull the cord any futher.If not you may have to dismantle the pull start and check the clips are not jamming.
Jul 06, 2009 | Toro Lawn Mower With Toro Power Tools
Case won't opem
There is a screw underneath the Toro label.   I learned the hard way.
Jun 09, 2009 | Toro& Electric String Trimmer
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
550 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
