Question about Saws
Looking for part for Clarke mitter saw model 1012 Plastic part that screws to table directly under where blade goes thur table top. Books says part number is bt 1012
  • 15 more comments
  • boodybll1 Jun 30, 2009
    There was nothing in the link as to a part for my Clarke mitter saw model 1012
    looking for a part for a Clarke Miter saw Model 1012
    wrong clarke this clarke only handles floor cleaning equipment.
    need part for a Clarke mitter saw model 1012
    parts for clarke mitter saw model 1012
    CLARKE IS OUT OF BUSINESS THAT IS WHY I AM LOOKING FOR A PART
    need part for Clarke mitter saw model l012
    I tried calling Clarke they are in chapter 11 not open any other ideas
    try calling the 8oo number yourself you will see what I mean. Stores are only sell what they have on stock
  • boodybll1 Jul 01, 2009
    need part for clarke mitter saw model 1012
    need part clarke mitter saw model 1012
    I looked on ebay. Where did you find it and what did you look under?
    clarke saw parts model 1012
    parts for clarke miter saw modle 1012
    They do not carry clarke saw parts
  • boodybll1 Jul 02, 2009
    SEEMS LIKE NO ONE KNOWS WHERE TO GET THE PART SO I WILL QUIT TRYING THANK YOU BILL
  • 10,515 Answers
To be really honest, looking by Part Number would not yield any result. Let me provide you with the link for Best People for accessories for Clarke Miter Saw :-
1. http://www.mitersaws-store.com
Call them at :-
(800) 718-1710
2. http://www.toolbarn.com/category/mitersawacc/
Call them at :-
(866) 597-3850 M-F 8-5pm CDT
These would be the best options i believe.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 01, 2009
  • taran_2005
    taran_2005 Jul 02, 2009
    I am afraid in this case, if possible look for the Part/Substitute from the local store. I have already searched extensively and no where i found this part number .
    I agree it's frustrating, but that would be the Best solution.
  • 66 Answers
You should try to go to your local Lowes and see if they have what you are looking for. If not there try Home Depot
  • 67 Answers
On ebay you can find the part by looking up the part and the result i just found it you can order it for a cheap price that is how you find and thank you
    President:
  • 942 Answers
Just copy this site for more information,
http://forums.jlconline.com/forums/showthread.php?p=469839
    President:
  • 1,952 Answers
'm not sure I completely understand your question, but I "think" what you mean is if the height of the blade is important. Yes, it's important for a couple of reasons, here's why:
First, the angle in which the tooth of a sawblade cuts the wood will affect the quality of the cut. When the blade is low, just barely popping though the surface of the wood, the angle at which the tip of the blade is coming though the wood is a very low angle. This means that the teeth are engaged into the wood for just a millisecond longer than if the blade was higher, and coming down (or up) through the wood at a more severe angle. This angle not only affects the quality of the cut, but also the heat that builds up within the saw kerf.
Cuts with a low angle can be inferior to cuts with a higher blade angle. Luckily, sharp blades make this difference very minimal.
More importantly, especially for the amateur woodworker, is the height of the blade in relation to the wood because of safety issues. The less of the blade that pops through the wood, the better, in terms of having actual blade exposed and potentially cutting someone.
Now I'm not sure if you were talking about an actual circular saw, in which the blade is exposed on the bottom of your wood, or a tablesaw, on which the blade is exposed on top of your wood. Either way, the potential of being cut from that exposed part of the blade is the true "danger" point.
I tell my students to adjust the blade so a mere 1/8" is poking through the wood. If anything should come into contact with that little sliver of blade popping through the wood, the damage is limited, and at least you're not going to lose a finger with only an 1/8" deep cut. Or at least that's the theory!
I can help with your warped table problem, I'll need a little more information. What is the top made of - solid wood, or some composite material, like MDF or plywood?
How is it attached on the underside to it's base?
Is the top treated the same way as the bottom? Like - if there's felt on the top, is the bottom bare wood, or does it have some sort of covering on it, too?
Is it in a room that is climate controlled? Or in an unheated patio room, in which there is no heat/air conditioning?
Wood tends to warp for a couple of reasons, the main culprit is humidity in the air. That's why a drawer or door might be hard to open at certain times of the year, and easier other times. I suspect that your poker table top is moving with possible heat in your home. It's drying out, and as that moisture leaves, it's warping.
Look under the table to see how it is attached to it's base. Is there any way to press the table into being flat again, and then adding some screws to hold it that way? Keep in mind if it's solid wood and you do this, it might crack apart.
If this table is located too close to a heating duct, it might be getting the full force of that heated air, thus drying it out and making it warp.
I suggest you think about where this table is placed, and consider that to be the culprit of the warpage. If you can't figure it out, write back to me, with specifics about where this table sits, and I'll try to help more. But for right now, this is only a guess until I have more info.
It's quite possible this table might flatten out when the season chages and the humidity in your home adjusts. Simply putting something on it won't make it go back to normal, but if you do manage to make it flat again, adding some screws or brackets to the underside (attaching the top to the base better) might help somewhat.
  • 2,200 Answers
I believe I can help you with this just looking at my parts catalog now. Will post up an answer shortly.
Posted on Jun 30, 2009
  • 1 more comment
  • Radio Code Pro
    Radio Code Pro Jun 30, 2009
    I believe you are referring to the lower guard is that right?
    The part no is BT1012A52
    Clarke can be contacted at this address
    Clarke Power Products Inc.
    Corporate Office
    28740 Glenwood Road
    Perrysburg, Ohio 43551
    You may also contact them toll-free at 800-227-9603 or at 419-930-2299.
    Customer service center is open Monday through Friday, 8:00 a.m. to 5:00 p.m. EST
    For all parts inquiries, please e-mail parts@clarkeusa.com.
    The website is http://www.clarkeusa.com/index.html
    I believe this is the company that makes your mitre saw. They still have tools for sale on tool-mall.com so must still be in business.
    Hope this helps.
  • Radio Code Pro
    Yeah. I think you could try these guys. They based in UK as Clarke International and I am almost sure its the same company. http://www.clarkeservice.co.uk/
    You can send a request to the parts dept. on that page.
    If Clarke are out of business it might be just as easy to get the part machined by a shop. They would knock that up for you for a few dollars out of light alloy. Still do the same job!
  • Radio Code Pro
    Yeah. As I say if Clarke are out of business it might be just as easy to get the part machined by an engineering shop.
    They would knock that up for you for a few dollars out of light alloy. They will make it to fit your saw and still do the same job!
  • 240 Answers
Kmoddl.library.cornell.edu/model.php?m=493 patentstorm.us/patents/4951540/description.html these sites will be helpful for fixing ur prob just check on
    Sergeant:
  • 322 Answers
Try looking to junk shops. There are some piece there that you can find. Junk shops are good places in finding for old types of appliances.
  • 258 Answers
Ok you mean Clarks miter saw, your only bet is to contact Clarks directly ok......Here is there contact details for you......
Clarks Supply and Service Ltd.
Rob Clark Sales Manager 306-693-4334 rclark@clarks-supply.com Kirt Blatz Territory Mgr Cell: 306-536-6660 kblatz@clarks-supply.com Kevin Blatchford Manager Cell: 306-630-6425 kblatchford@clarks-supply.com Lannie Erickson Construction 306-693-4334 clarks_supply@hotmail.com
  • 294 Answers
Hello boodybll1.. m glad to inform u dat i have wat u want. accept for that plastic thing.
http://www.repairclinic.com/Appliance-Parts?searchText=Clarke%20mitter%20saw%20model%201012&Search=Part%20Search
Hope this ws helpful......>>cheers!!! "old guy derserve a drink man!!!"
  • 508 Answers
    President:
  • 392 Answers
Please go through this link u will get some idea . click here
please rate my answer . i will get paid for the service done.
How do i replace the blade on my Sears craftsman 16 in. Direct drive scroll saw model no. 113.235501 , please help
the blades will have small pins at each end
fit it in the table end first as this is the end that does the work
then pull the top down to fit the blade in the slot
The top is normally only spring loaded
Aug 08, 2015 | Craftsman Saws
Brush replacement
If its a direct drive, on the motor there should be two plastic looking
flat head screws about 5/8 " in diameter on each side of the momotors crew those out , with the power off , slide the brushes out
slide the new ones in
Apr 23, 2014 | Craftsman Sears Table Saw Manual Model...
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have an older Craftsman's Table Saw. I use it for a few minutes an then it looses its torque and can't saw no matter the thickness of the wood. Is it the motor?
Is it with belts connecting from motor to blade , or is it direct drive ( like in a circular saw) ? Belts do wear and need to be tightened or replaced. If it is direct drive, is could be the motor contact brushes on the armature that are burned or worn. They will allow the motor to run but not give the power when called for. Brushes are usuall y accessible from the outside of the motor from small plastic (bakelite) screw caps (2 of them). Finallt, it could be the blade lock nut and tension washer. This you will know because the blade will begin to snow and not cut the material, yet the motor sounds as if it is running standard speed.
Nov 27, 2010 | Craftsman 10" Table Saw
My fence is square to the table. How do I set the blade so it is square to the table? There is a 1\8" difference in the distance between the front and back of the blade in relation to the groove the miter...
I'm betting that the table isn't square to the blade. My Cabinet Makers Table Saw does the same thing - the top plate (the big heavy cast iron plate that weighs about 50 pounds) sits on top of the sheet metal box that houses the motor and motor lift. This cast iron plate is held onto the sheet metal box by 3 screws (usually).
Loosen the 3 screws and the cast iron plate can move around on top of the sheet metal box (the holes for the screws are large enough to allow 1/8 inch movement). Looking down from the top, you can rotate the cast iron plate clockwise and it will move the front of the blade closer to the fence and the back of the blade away from the fence. Counter-clockwise does the opposite.
For the best adjustment, use a dial indicator mounted to something that slides in the track of the table top. Position the dial indicator agains the blade and slide it back and forth in the track of the table top. This will accurately set the table top to the blad (so they are parallel within 0.0005 inches).
Then check the accuracy of your fence (sounds like this is good). Don't forget to check the alignment of your riving knife/guard & splitter to the blade (if it's off you can't feed wood because it will hit the splitter).
Oct 07, 2010 | Delta Machinery 3 HP Left Tilt Unisaw with...
I need to know how to change the blade.
Table saws come with tools for this purpose. You first must remove the plate next to the blade on the top. Usually held in place with two screws. Once that is removed you use the tools to hold the blade in place with one tool, while removing the nut holding the blade on with the other. Notice the direction the teeth are turning.
Apr 22, 2010 | Saws
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Nov 03, 2009 | Saws
I need to replace the blades on a Sears Scroll saw. Model # 149236160
Your scroll saw should have come with Hex end tools to use when changing out the blade. You must release the tension on the blade (located on top of arm above blade). There is a small allen head screw which has to be loosened with an allen wrench to release the blade. There is also an allen head screw under the working surface which will have to be loosened to remove blade at the bottom. Replace blade at the bottom 1st, tighten up then go to the top, tighten it, then reset the tension and you're ready to saw again. Make sure to get a visual on the directions of the blade teeth before you remove it so you can replace the new one the same way. I hope this is helpful.
Sep 26, 2009 | Craftsman Saws
I have a Delta heavy duty construction table saw and the blade needs to be alligned to make it cut straight. Nothing appears to be bent. How do I adjust the screws to improve my ctting.
I have the same saw and love it. There are mounting bolt under the table between the blade and the motor. There not ment to be used for adjusting but there is some play. The way to get the best cut is to adjust the fence to the blade. I have a Bessimer fence that adjusts easily with two allan machine screws the push plastic pads against the arms rail. I get cuts that look like DA with 220 was used. Enjoy the saw and good luck.
May 02, 2009 | Saws
Saws Logo
466 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
