Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Loss of power when mower engaged - Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
  • 127 Answers
This is usually caused by a dirty restricted fuel filter as the engine has more demand put it with the deck engaged change filter and install with the arrow pointing to the carb
Posted on Jun 30, 2009
Cub Cadet 1610 loss of power when mower blades are engaged?
There could be a number of things. #1 your neutral switch could be bad or going bad.#2 the brake switch could be bad or going bad. #3 your seat switch might need adjusting or it too is going bad.
May 06, 2017 | Cub Cadet Garden
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
24hp briggs and stratton intek power loss under load
Exhaust clog, stale gas, clogged fuel filter.
Aug 13, 2014 | Poulan Garden
Power loss
sounds like the engine is running lean caused by dirty jets inside the carb
Aug 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Loss of power
the carb might need a good cleaning
May 31, 2012 | Craftsman Garden
Murray ride-on lawn mower model 155/107 (15.5 HP Briggs & Stratton engine). Engine starts o.k. but cuts out as soon as the hydraulic clutch is engaged via foot pedal. ie foot on clutch to start...
two possible problems. check power from safty switchs, put the lever down under the seat and rock the back tires back and forth until you here a click. then try again. a safty swith is giving you problems
Apr 25, 2011 | Garden
Riding lawnmower loss of power, runs ok at first but in 1/2 to 1 hr loss of power, replaced fuel filter/fuel kit
you need to check compression. sound to me that ether the valves need adjustments or you have cylinder damage causing compression loose when engine warms up. send me the model# of the mower and engine too.
Feb 09, 2011 | Garden
The mower starts easily but loses power and stalls out
You may need to adjust the fuel mixture screw on the carb to allow more fuel under load. And check to see if air cleaner is clean.
Apr 20, 2010 | Mtd 22" Yard Machine Push Mower
Loss of power when engaging deck
check your compression. if you have a two cyl engine, start it and ground out each cyl (or pull off the plug) see if engine changes the rpms if one don't change check spark and compression on that side. if you only have one cyl go back to checking compression. get back to me with what you find. ps check your belts to mack sure nothing is in the pulleys like a stick and check under your deck to make sure you don't have a grass build up.
May 12, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
578 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
