Question about Sony SRS-BTM30 Computer Speakers
Stereo speakers not working on my lap top - Sony SRS-BTM30 Computer Speakers
    Problem Solver:
  • 5 Answers
Fixed this problem finally. This solution is for Vista. It's quite a process getting them connected! Make sure you've paired the speakers and that went fine. Turn the speakers on. Click the bluetooth icon in the Task Manager. Click on the "Bluetooth Settings" tab from the menu. A dialogue box called Bluetooth Radio Properties opens. Click the Audio tab. If you've paired your speakers right you should see them in the list. Highlight them and click the "Connect" button. The speakers should then connect. Make sure they are set as the default device (use the Volume Mixer from the Task manager to do this) and you should be right as rain.
Posted on Aug 29, 2009
How can I hook up the 5650 system to my lap top?
The laptop has one RT/Left mini port on the side or up front. You may require and adapter to a larger stereo plug if the Mini Adapter is too small for the speaker line input. If you have Two wires to the speakers and no Mini-Plug, you need Converter from Mini Plug to Right and Left Ports. Best you take it with you to RadioShack and they will match up the adapter you need then and teher.
Jan 04, 2014 | Dell 5650 Computer Speakers
I am not able to get sound out of the projector. I have the proper cords attached. I am able to get sound from the lap top. Help
The Vivitek D825MS Projector does not have any speakers of its own. You have to use an outside source for sound. Another set of speakers connected to the laptop might help, or if you have access to a plug in through a stereo or mixer to take the sound from your computer to the speakers hooked up to the stereo or mixer, that is ideal.
Hope this helps.
Jan 25, 2011 | Vivitek D825MS Projector
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
2005 freightliner columbia. replacing factory radio. All wiring is grey :-( Anyone have a diagram showing what pin is what?
Holding the harness and looking at it as it would plug into the back of the stereo you have 8 wires in the top half of the harness and 4 in Tue bottom. Working left to right on the top half first is the rear left speaker, front left speaker, front right speaker and rear right speaker. The positive speaker wires are on top the negatives are on bottom.
For the lower half of the harness you have 1 wire in the top row and 3 in the bottom. The one on top is the switched wire to turn the stereo on and off with the ignition. The bottom row from left to right is ground, and 2 constant power wires for stereo memory you can use left right or both to connect to your stereo's memory lead. I hope this helps I was looking to and had to map the wires using some educated guessing and a multi-meter.
May 31, 2010 | Car Audio & Video
I just connected your z-4 speakers toshiba
Found thru "tools' -"speaker settings" that the "stereo speakers" box was not checked.
Jan 21, 2010 | Logitech X-530 Computer Speakers
Only a dynamic mic works on my lap top not condenser mic
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Sep 21, 2009 | Samson Audio C01upak C01u Microphone and...
My base won't work with my logitech speakers
You may need to upgrade your logitech sound driver for Vista
Dec 28, 2008 | HP 2133 Notebook PC
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Sony SRS-BTM30 Computer Speakers Logo
323 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
