Question about Hamilton Beach Coffee Grinder 80355
Coffee grinder won't turn on - Hamilton Beach Coffee Grinder 80355
3 Suggested Answers
SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Posted on May 21, 2008
bcarson750
  • 5 Answers
SOURCE: coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Posted on May 16, 2010
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Will not turn on
all parts in place, won't turn on
Aug 30, 2012 | Cuisinart Supreme Grind Automatic Burr...
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
My coffee grinder won't spin slowly
now is it working on slow or it going to fast ,as you have made two postings ,and both contrary so if its playing up then buy a new one as its cheaper than a repair .
Nov 12, 2011 | Coffee Makers & Espresso Machines
Machine won't turn off after grinding beans. have to unplug it and wait 20 seconds before repluging it to stop.
Just replace the relay which drives the grinder.
Thats all
You are good to go
Thanks
Please rate my work
Sep 10, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Jan 30, 2010 | Cuisinart (CCCCUISINART) Grinder
Grinder completely unresponsibe.
Hi
If you have tried opening the adjustment to a larger # and it still doesn't work. Well if the motor won't turn, I only hope the machine is less than a year old because the likely problem is the motor is bad. Sorry
Oct 25, 2009 | Rancilio (RAROCKYND) Grinder
Hamilton Beach Coffee Grinder 80355 Logo
1,008 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
