Question about GE 25951EE2 Phone
Base set fine - additional handsets dont work
The base set seems to work fine, but when I push talk on the additional hand sets, they say unavailable.
The additional handset and the base need to "pair" first. Put the handset in the base cradle till you see the red light blinking. That's when they are paired.
Posted on Dec 08, 2007
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
Jill,
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
Can't re-register extra receiver
Try this, Push and hold the "End" key, while still pushing the "End" key push in the "#" key and hold both keys till you hear a beep. The LCD display should now say "De-register Handset" and under that "Base Unavailable" Select Base unavailable. The LCD should now say "Handset not registered, place in base" Just set it in the charging cradle on the base unit and it should register to the base.
Feb 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
CAN'T TALK ON HANDSETS I CAN HEAR THE PERSON THEY CAN'T HEAR ME TRTHE BASE WORKS FINE I JUST CAN'T TALK ON THE CORDLEES PHONES
You have to unplug everything, take the batteries out of all the phones, wait ten minutes and then plug everything back in. Mine does this once or twice a week... they won't give me my money back.
Dec 26, 2008 | GE 25881EE3 Phone
Do not disturb on phone is lit up
ON THE BASE, there is a button that says do not disturb on the lower right hand side on mine and I accidently hit it and turned it on!! I kept trying to fix it with the handset and the menu!! My husband suggested I look at the base and WAHLAH!!! I simply pushed the button and it worked!!!
I'm trilled ...cause I was so frustrated!!! So...there you go!!!
Jun 30, 2008 | GE 25932 Cordless Phone
Probelm with registering additional headset for the philpsse 7450
OK here it is leave the additional hand set base plugged in & take the hand set with you to the main phone & base. 1. unplug the main base.
2. with the main base unplugged hold the find handset button on the base.
3.with your finger still on the find hand set button plug the base back into the power.
4.charge light on main base should be flashing.
5.while the light is flashing press & hold the hash # button on the additional hand set only until it says registration complete & its all done.
May 02, 2008 | Lands Phones
Registering phones
I have after many hours found the solution. (Well one that worked for me). I have a Uniden Elite 8855 + 8805 additional handsets. What you have to do is:
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Jan 22, 2008 | GE 25942GE2 Cordless Phone System
Ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Jan 14, 2008 | GE 25932 Twin Cordless Phone
My new hand set will not detect my base
Have you followed the instructions for handset registration? For some of the newer handsets, you may need to refer to the instructions that came with the handset (and not the base) instead of just putting the additional handset in the base to register it.
Page 23 of the 9480 manual gives explicit registration instructions.
Jan 07, 2008 | Uniden TRU9480 Cordless Telephone
Phones Not working
I have the same problem, I have the same model and sometimes I have to put the 2nd Handset on the main base and let the main base "rocognize it" before I can use it. That usually fixes the problem for me.
Apr 02, 2007 | GE 25861GE3 Phone
GE 25951EE2 Phone Logo
315 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
