Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Fast Blinking Timer Light
I know this means that it is in the start up mode. But it should stop blinking after about 1 minute. It has been 8 hours. Has anyone found the answer to this yet? It seems common but I have not found "fixes."
  • 64 Answers
If the timer light blinks at the same rate all the time...then the problem could be fairly serious (the tv won't start up). If the blinks are NOT consistent..then count them...it is an error code for service personnel. Try resetting the tv or plugging it out. Wait. Then plug it back in (resets the tv) and see what happens.
Posted on Aug 01, 2009
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    How to set time for aquastar N0 4095
    When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
    Nov 02, 2009 | Watches
    Athletic wrist watch stuck in 24 hour mode
    Maddening, isn't it? Fortunately the solution is here:
    http://www.ehow.com/how_5593310_set-athletic-works-watch.html
    1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
    4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
    Apr 30, 2009 | Watches
    Kenmore Ultra Wash Dishwasher LIghts are blinking....
    I suspect for either of these units that the timer control boards are bad.
    Jan 24, 2009 | Dishwashers
    I dont know how to set the time
    How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
    PLEASE READ CAREFULLY
    STEP 1:
    First hold the button for set/light.
    STEP 2:
    wait for the "hold to set" message to appear
    once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
    TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
    STEP 3:
    To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
    *If you are done setting the time press the set/light button, and there you have it.
    If you still need to change the minutes of your digital watch proceed to step four.
    STEP 4:
    After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
    To set MINUTE:
    press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
    *If you are done setting the minute, press the set/light button, and there you have it.
    If you still need to change the date specifically, the day of your watch proceed to step five.
    STEP 5:
    To set date, specifically, DAY:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
    To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
    *If you are done setting the day, press the set/light button, and there you have it.
    If you still need to change the date specifically, the month of your watch proceed to step six.
    STEP 6:
    To set date, specifically MONTH:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
    To set MONTH:
    press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
    *If you are done setting the month, press the set/light button, and there you have it.
    If you still need to change the date specifically, the year of your watch proceed to step seven.
    STEP 7:
    To set date, specifically YEAR:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
    To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
    *If you are done setting the year, press the set/light button, and there you have it.
    If you still need to change the 12/24 hour format of your watch proceed to step eight.
    STEP 8:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
    To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
    *If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
    If you still need to change the power hour of your watch proceed to step nine.
    STEP 9:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
    To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
    Press set/light to set POWER HOUR.
    Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
    Tv won't power on
    I trashed the set and bought a new one.
    Jul 02, 2008 | Mitsubishi WD-52725 52". Rear Projection...
    Can't reset the time on digital watch
    I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
    Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
    Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
    Mar 22, 2008 | Watches
    RCA,RP9328A,Audio System
    I did the following to set the clock:
    1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
    2. Press Set/Demo. The hour indicator on the clock should start blinking.
    3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
    set the hour.
    4. Press Set/Demo. The minute indicator on the clock should start blinking.
    5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
    set the minute.
    6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
    Feb 09, 2008 | Audio Players & Recorders
    How to set watch
    I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
    2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
    Apr 02, 2007 | Kenneth Cole RK5034 REACTION
    Mitsubishi WD-52525 52" Rear Projection HDTV Logo
    98 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
