Question about GPS
Have been a big fan of your products but am disappointed in the last 498 that I bought .my boat just went back in the water after repowering it put the unit on ready to go fishing and was unable to find satlelite.need unit ready for next week on vacation Bob Bevan unit #70714755 Help!
    Brigadier General:
  • 4,090 Answers
BOB you dont say whethert your boat was under repairs or whether the unit was permanently connected.
Soemtimes when the battery terminals are removed on the boat while in storage or reapirs a spike can occur and damage the unit. If the unit has a backup batterty check that its OK. you did not state the brand so its going to be a general answer. If you have spiked the chip then an expensive repair is needed.
Posted on Jun 30, 2009
Looking to repower 1997 Four Winns bowrider with newer outboard engine. What max HP is boat rated for? Found Yamaha 150 XB 2016 for a good price . Will boat work with a 25 inch shaft? Thanks,Kathy
there should be a manufacturers plate attached to the hull of the boat with a number of passengers it can carry and the max hp motor allowed to be fitted
talk with boat shops as they will know the approximate hp for each make of boat and length
while it may be attractive to fit big hp motors to small boats , it in fact makes the boat less sea worthy and makes capsizing easier so get the advice right from the boat shops
Feb 07, 2017 | Yamaha Boating
Do I have to cover my trailer boat when towing?
I do not know the rules of your state but I do not know any that require a cover. The bout should be strapped down to the trailer and anything that can blow out should be removed. I followed a boat the other day that had a hatch unfastened. Round things were blowing out as the lid flopped in the wind. I stopped him, then went back to see what came out. He will be unhappy when he gets on the water and finds he does not have any leader line left.
May 10, 2014 | Boating
Bought boat need manual
http://www8.garmin.com/manuals/1068_OwnersManual.pdf
Sep 26, 2010 | Garmin GPSMAP 498 Fishfinder /...
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Are my water jackets plugged
hi there is a water inlet on one side this takes cooling water up to the engine block then the water circulates through the block then into the exaust manifold then out into the drive along with the exaust gases and comes out through the prop blockages usualy occour in the maifold but they can be almost anyware dissconect the big hose going into the drive and put a hosepipe up the smaller one water should circulate /put big hose back /water should come out of prop if it is possible put the leg in a cut down 50 gallon drum make a solution of 10lb caustic soda to 30 gallon HOTwater run the engine in that for half hour or so then run it in CLEAN water for an hour the last thing youi want is any caustic left in the motor hope this helps merlin v1`2
Aug 26, 2009 | Boating
How can I download a manual for a Garmin Gps 498
Here's the link to download the manual for free. If this solves your problem, please come back and rate our solution.
https://buy.garmin.com/shop/shop.do?pID=370
Jul 31, 2009 | Garmin Gpsmap 498, External Antenna With...
99% of the time when i power unit up, it gets stuck on 54.8 feet
After testing everything out, I went out and bought the new Eagle Cuda 300 model. I hooked that up and made sure it worked, then tried the Cuda 242 unit on the new transducer. That did it, it worked fine. The problem was a bad transducer. Might have been that -30 deg weather last winter, I'm taking that off the boat this winter. Transducer cost about $50-$60, new Cuda 300 cost about $80.
Mar 22, 2009 | Eagle Cuda 242 Fishfinder
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Depth display
reset your factory settings!
Oct 02, 2007 | Garmin GPSMAP 498
GPS Logo
57 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
