How do i bypass the parking brake feature on my Jensen vx7020 so my son can watch movies while i drive?
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
You dont its a safety feature so driver doesnt get distracted and its ******* in almost all states to have video on while driving
You're offered a satisfaction code. Create the code on your invoice, My BK Experience This number needs to be published at the top-most component of your invoice.
Not simply that you could even get Ebooks, wallpapers, Ringtones so on free of charge appvnapkdownload complimentary, with a growing number of being added everyday.
Ground parking brake wire.
Wire the brake wire with the ground on your stereo.
SOURCE: bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
SOURCE: jensen double din dvd monitor uv8020
Here's what you need to know: DVD
head units have one extra wire in their wiring harnesses, compared
to a standard CD head unit. On the Jensen, it's a peach-colored wire,
and is
the activation wire for the DVD feature. During the installation, the
instructions call for this wire to be tapped into the emergency brake
indicator light wire. The reason is this:
The e-brake indicator
light is what is called a "ground complete" circuit. That means that
the bulb always has power applied, but when you pull the brake, that
puts a ground to the wire and completes the circuit, allowing it to
illuminate. The head unit sees this ground, and activates the DVD
player.
In mine, I simply ran this wire to a ground (I
used a screw near the fuse box), and I put a switch on the wire, so I
could break the ground contact at will. Jensen calls for a procedure to
activate DVD playback. In their instructions, they tell you to select
DVD from the option menu, and when the "lawyer screen" comes up (the
one warning you to park before you watch a movie), you release the
e-brake for 3-5 seconds, and then reapply it. To simulate that with the
switch I used, I leave the switch closed (activated), and select DVD.
Then I flip the switch "off" for 3-5 seconds, and flip it back "on".
This tricks the head unit into thinking I put the e-brake off for a few
seconds and then put it back on, and the movie will start. Then I can
drive away.
Basically, ground the wire that is used for DVD
activation, and put a switch inline on it. Then you can break and
reapply the ground in the manner of the e-brake cycle I mentioned earlier.
SOURCE: Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
SOURCE: bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
SOURCE: Need to bypass parking brake feature on Jensen VM9512HD
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Pull the unit from your dash (assuming it is installed already),Find the ground wire (-12 volt
Strip the ends off of the wire that is supposed to be connected to the parking brake, the ground for the dvd player and the ground wire from the car. MyBKExperience
