Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I have a model DCC-1200BW. It powers on but won't
I have a model DCC-1200BW. It powers on but won't heat or brew the water.
  • 85 Answers
Hello artiklisa,
Sometimes the problem you have with your unit can be due to a clogged system.
I recently had this similar problem.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
How do I clean my cuisinart DCC-12
1/3 cup of white vinegar and 2/3 cup of water. Run through brew cycle. Run brew cycle again with plain water.
Sep 14, 2010 | Cuisinart DCC-1200 Coffee Maker
Shuts off in the middle of a brew or loses auto brew
In the last few months, my Cuisinart DCC-1200 Coffeemaker has started shutting off in the middle of a brew cycle and if I set it the night before, it doesn't start brewing at the time set for. At first I thought it was related to the GFI outlet I have it plugged into, but now I am convinced it is the coffeemaker itself. Since it is now about six years old, it doesn't owe me anything, but I will consider a different model for a replacement.
Nov 17, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
Jan 10, 2009 | Cuisinart DCC-1200 Coffee Maker
Will not brew after a power failure
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor````
Jul 14, 2008 | Cuisinart DCC-2000
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
One year old coffee maker won't brew
I had the same problem, only this happened on the last 3 dcc-2000 I purchased. I called customer service today, and they informed me that there is a 3 year warranty on this product. Wow... This time they really helped. I have made 2 phone calls to customer service, and was put on hold for over 20min. each time they found out what machine I was calling about. Call customer service, and don't give up!
the number is 1-800-726-0190. you will need the serial # from the bottom of the unit (stamped in) and the model #.
good luck! Bob
Mar 30, 2008 | Cuisinart DCC-2000
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
288 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
