Question about Sony SNT-V504 Video Server
0 characters
1 Points
I have Lantronix-SCS400,i forget it's ip and i wanted to reset it,the reset button seems broken,is there any other way to reset it to default??
To reset the SCS to factory so you can assign a new IP, use a paper clip to depress the button inside the reset hole. Hold that button and recycle the power, continue to hold the button after power cycle for 15 seconds.
Nov 29, 2010 | Lantronix Secure Console Server SCS400...
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
run winsock fix from
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Other Network Devices
I clicked the release button on my status page, and now my internet isnt working and i cant click anything, whats wrong??
It should have reconnected automatically, but in any case that it hasn't reconnected just restart your Barricade by pressing power button OFF then ON.
It should have a new IP address provided by your ISP.
Hope it helps. Thank you for using FixYa.
Jan 16, 2010 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
The ip adress web page is not letting me log in is the default password and username the same as always?
The default ID either is 'admin' or it is a "blank" value.
The default password either is 'admin' or it is a "blank" value.
So, try all 4 combinations.
Jan 09, 2010 | Other Network Devices
Router Problem
Go to start / run tye in the run box (cmd or (command) then in the plack screen type in ( ipconfig /all ) look for the defalt gateway that will be the ip adress you need to type in to get to the router login unless you have a complex network
Sep 21, 2009 | Black Box IP Address Translator With...
How to hide ip-address,find ip-address?
Well you cant hide ip address. But you can use a proxy server that well mask you ip.
and to find your ip you can goto
Sep 15, 2009 | Other Network Devices
Guidance setting up a shared connection :)
1- set up router trough desktop
2-run program for wireless, after it gives you the IP ( which it already has, set user name and password for protection)
3-set up the laptop as a "Shared folder" along with the printer if there is one.
Aug 24, 2008 | Other Network Devices
Xbox 360
Try and check your RAM. If you have two RAMS remove one let the other runs for some time and observe, if it continue misbehaving change over to the other RAM. am sure either of the RAM is bad or if it only one RAM try and check wit a new one.
May 31, 2008 | Black Box IP Address Translator With...
My ip address need reset
to reset your ip address simply unplug your modem and router, turn off the computer, turn on the computer with out pluging the router and modem back in, turn the computer off , plug the router and modem in wait for the lights to come on and then turn your computer on.
May 14, 2008 | Black Box IP Address Translator With...
Sony SNT-V504 Video Server Logo
23 people viewed this question
Top Sony Other Network Devices Experts
 C. Dante
C. Dante
Are you a Sony Other Network Device Expert? Answer questions, earn points and help others
