Question about Garden
Need brass worm gear for a GIL39000A rototiller
4 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Posted on Jan 15, 2009
spekgt
  • 60 Answers
SOURCE: need specs.for Honda rototiller motor
Hello
The valve clearance is 0.08 for intake valve and 0.11 for exhaust valve . To do the timing you have to remove the spark plug and set the piston at top dead center (all the way up) and on the cam pulley you have a mark (like a triangle) that you have to align with the fan cover bolt hole . Hope this help
Posted on Aug 29, 2009
The cam to crankshaft.... the plastic gear has a dot that you can see. mark the tooth with a sharpie so you can see it visible. its a cicle on the cam gear. on the crankshaft the cylinder needs to be at top dead center so when you put it back in all the way to the top. on the gear there is a notch that you line up the tooth on the cam to the two on the crankshaft. Its easier if you take the flywheel off to put it together. Hope I made sense
Posted on Aug 30, 2009
Rattling noise after changing the planetary gear
The housing has to be worn if the bearing has play. Try a little tape around the bearing, or some thin brass shim stock. Of course epoxy may be a solution, if applied around the i.d. of the bearing seat. A little shortning on the bearing will keep it from sticking to the epoxy.
May 25, 2014 | KitchenAid New Professional 5.5 QT...
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
What kind of spark plugs do i need
Try this site: http://www.lawnsite.com/showthread.php?t=214090
It has blogs about this type of old tiller.
Aug 04, 2012 | Atlas Translator Atlas Rototiller Worm...
Tines do not move in my poulan PPB2000T cultivator attachment
PPB2000 more than likely has stripped a gear in the gearbox. The drive cable is probably ok. Tines are driven by a worm gear and brass gear. Internal parts of gear box not available.
jas
Apr 24, 2012 | Poulan Cultivator Attachment
Hobart a200 will run just fine without anything in the bowl, once I pour my ingredients into the bowl, it wouldn't even mix the ingredients. Try all 3 gears.
Short answer: something is worn/broken inside the mixer's transmission.
Longer answer:
Since none of the three gears operate, the problem is most likely on either the worm gear shaft (probably the brass worm gear itself) or the "transmission shaft" (ironic name as all three shafts could be called transmission shafts). If you're up to the task of disassembling the transmission, which is a very messy task, you'd probably find the problem on one of the two smaller shafts inside the transmission. You'll most likely find either a broken key or worn brass worm gear. Both of these items may have enough holding strength to operate under very light loads (such as an empty bowl) but slip once a load is presented.
Also check the planetary key. Remove the planetary by removing two nuts on the underside of the transmission, where the attachments attach (careful, as the whole thing will drop once the second, thin nut is removed). You will find a long key on the shaft (or in the planetary gear, whichever one it sticks to). Make sure it's not broken, and re-attach the planetary.
Aug 12, 2010 | Hobart A200 Stand Mixer
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Need a drawing of the worm shaft and spool valve assy.
closest I have is 94 explorer. may be similar.
Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
May 09, 2009 | 1983 Ford F 250
Jan 15, 2009 | Hobart A200 Stand Mixer
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
