Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
TEW432-BRP HW Rev D has random drops. It just tends to drop the wireless any time it feels like. Disconnecting me from everything. Its very annoying and I need this fixed or I can't use this router :/ Firmware update didnt fix it either.
  • 375 Answers
Have you done a site survey? It may be that one of your neighbours is using the same channel.
Try moving to a random channel midway in the range, usually setup programs start at the bottom and don't take into account the fact that other Wifi device might be local.
Posted on Jun 29, 2009
I have an 03 Jeep Grand Cherokee v6 2x2 with 170k... I'm having a couple of issues... 1. Occasionally will have trouble with cycling through gears when getting on Hwy causing decreased, sluggish...
I would consider changing the vehicle speed sensor. When they go bad, they can really throw out a lot of bad data to the computer, resulting in unexpected behavior like you're experiencing. They're only around $20-$25. I hope this helps! :)
May 02, 2014 | Cars & Trucks
PROBLEMS LOW IDLE TOYOTA COROLLA 2006 AFTER CHANGE BATTERY
if it has an oil control valve try replacing that good luck
Mar 10, 2017 | 2006 Toyota Corolla LE
My Belkin N750 DB intermittently drops my internet connection to both wireless and ethernet connected devices. I POR it and it works fine until the next time it quits. Is there a fix or is this just an...
Some people turn everything off at night and then when they turn things back on everything starts powering up. If you do this, it may be the problem because you have the modem and the router starting up at the same time. If the router finishes before the modem then it will drop.
Just make sure that you turn your wireless router on after the modem had booted up. This problem also happens when you have a power outage in the house and they both boot up at the same time.
When ever you are experiencing drops, just go unplug the wireless router then plug it back after about 30 seconds.
Jun 03, 2012 | Belkin N750 DB Wireless Dual Band N Router
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
Stiff accelorator pedal
It is either the cable that goes from the pedal to the throttle body, or the throttle plate is sticking.
Mar 30, 2009 | Hyundai Motor 1998 Accent
Mazda 626 1989 car rev high then drops very quick
its most likely your throttle body posistioning sensor have it checked by shop with OBDII diagnostics but checkers autoparts will scan your computer for free with scan tool and identify it.
Jan 21, 2009 | 1989 Mazda 626
My zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
Jan 17, 2009 | Zyxel Prestige 660HW Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
227 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
