Question about Proton MM2701VT 27" TV
Tv switching off
Hi
My tele turns itself off within seconds i dont get chance to look at any menus, please help!!!!
jEN
    Problem Solver:
  • 11 Answers
Its a minor problem,get a tech to fixed that.
Posted on Nov 28, 2007
My DSL 2730 U ADSL router is getting switched off automatically within seconds, it powered on. No other LED's turning on. Can anyone help to resolve the issue.
I would try a factory reset. If the router is physically powering itself off chances are you have defective router.
Aug 04, 2016 | Computers & Internet
The screen and standby light dont work but touch sensitive buttons still beep
Look for any loose contacts in power outlet, RC Jack, cable and connectors. In order to ensure, it is not caused by the input device, connect a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Televison & Video
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
I have a 46 inc panasonic plasma tv. when i try to switch the tele on with the main button on the tv the light just turns red and it dont switch on. i have tried to diconect the power which use to work now...
turn tv on and leave it on for a while. A light will flash for a couple seconds count the blinks and let me know they use a blink code to narrow down which board may be faulty.
Apr 26, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My television shuts off by itself within seconds of being turned on. is there a reset button to fix this issue?
There isn't an external reset button on your TV, unfortunately. Resets to factory settings would have to be done through the on-screen menus and that's not possible if the TV won't stay on. A technician will likely have to diagnose the cause and complete the repair. Service for your TV can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Nov 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
Tele will not stay on
The tv has an error code thats its way of telling you there is something wrong so it shuts itself down to protect itself. I would have it looked at or call philips and they can tell you what that means. hope that helps.
Aug 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My amplifier
The "switched off by itself" is indicative that the auto-protect is acting. Auto protect senses that there is something wrong within the unit and rather than the damage extend to other areas, it simply switches the entire unit off. On some models, this also hold true if there are no or faulty speakers connected to the receiver. In others, this happens when there is no intelligent signal received such as in FM when an antenna would be required.
If you have verified that it is not poor signal, speaker problem, then perhaps your best bet would be to seek the services of a qualified audio technician since this would involve electronic circuitry/component diagnosis, soldering and the use of a DVM.
hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Audio Players & Recorders
Tv
I had the same problem with my new TH-50PX60B. I turned the tele on then after 5seconds it would switch off. The standby light would then blink on and off 11 times, pause for a second then flash 11 times. This would continue until the power wasturned off. Note the TV would not turn on for more than 5 seconds.
I solved this problem by turning the tele on and checking the fans at the back. My tele had 3 fans. If one of the fans is not turning, this will be the cause of the problem and the tele will shut down under the Emergency Shutdown System. To clear the fan try blowing on it to free up any dust etc. If that still doesn't work try using a thin instrument (tie wrap etc) to manually turn the fan and free it. Then power off the tele and turn it back on. The tv should work perfectly.
Sep 02, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Proton MM2701VT 27" TV Logo
100 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
