Question about Magic Chef 31100 Gas Kitchen Range
Magic Chef super capacity range.
The digital clock will not hold the time. Keeps flashing and when trying to use the oven every time the clock goes back to flashing, the oven goes off. Disconnected the oven light and it started working again. But the next day same problem all over again.
Oven takes to long to heat, broiler works fine, even the clock works it's just not heating fast....the bottom lights up,but not the top?
Posted on Oct 14, 2011
2 Suggested Answers
  • 1314 Answers
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Posted on Jan 15, 2008
Our Magic Chef oven just began making a whirring noise and the clock stopped functioning properly at the same time.
Hi Peggy Freeman,
I suppose that it is a Maytag Magic Chef.
From your description my conclusion is an electrical fault on the clock.
You have to open the cooker and remove the connection to the clock.
BE CAREFULLY
Always insulate the connector, as it is mains grid.
When it is indeed the clok, the noise will stop, but you an not use the clock anymore.
Kind regards, Dik
Here you find a PDF of the Maytag Magic Chef:
https://www.repairclinic.com/UserManual/b8e1b97795884ea59496a9eaf1a93883/Magic-Chef-Range-Stove-Oven-Repair-Manual-CGL1100ADQ-CGL1100ADW-CLL1101ADW.pdf
Feb 08, 2018 | Kitchen Ranges
The digital display for a Magic Chef gas oven reads "5 A6", what does that mean?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Mar 21, 2013 | Kitchen Ranges
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas oven alarming and flashing F8
Hi wlfwoman2002,
The F8 failure code description is an Analog / Digital problem. To resove this error code, please replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using Fixya.
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Surface Heat and other lights will not light up. Will not get hot but is trying - gets slightly warm. This includes burners and oven. The cooking light will come on in the oven but nothing more. The...
you have a power promblem start where the cord connects to the range and go back from there to the fuses before you pull it out turn off the breakers loose connections will cause the cord to short out sometimes
May 24, 2008 | Magic Chef Kitchen Ranges
Magic chef range
Jan 15, 2008 | Kitchen Ranges
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef 31100 Gas Kitchen Range Logo
1,275 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
