Question about Ricoh FT5832 Copier
Where is the used toner bottle located on the lanier 5635/5645?
  • b_biggin Jul 02, 2009
    Where is the transport belt section and how do I get to it?
  • 203 Answers
The transfer belt is located on right side of the machine. When you open the duplex unit if you have on the machine which can be opened by the pull plug which is located on the right- front corner of the duplex unit and then you have another pull plug on the same location with which you will open the right door of the copier. Inside on the side of the opened door it has an black case on which has attached an brown belt on the top of the black case has an lite green colored pulling plug which has to be pulled up and then you can pull up the black case and remove from the machine than you will see that the brown belt can be removed and under the belt has a black seal on which has 6 screw's open it and inside you will see than a lot of toner has been loaded remove it with vacuum cleaner or empty the case in some bag or something and then repeat the procedure clockwise and turn on the machine and the problem is solved.
If this can't help you than better is for you to call a techinican
Posted on Jul 10, 2009
  • 3 Answers
I think on that model it fills up the transport belt section.
Needs to be removed, emptied and re-fitted.
Posted on Jul 01, 2009
How to replace used toner bottle on an LD245 and where is it located on the machine?
No bottle, it is inside the transfer belt unit that hangs on the inside of the right hand door. Dump it and put it back.
Jun 24, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Full waste toner bottle Lanier LD540C
The boys at the office figured out how to get out and empty... Thanks for all your input... I had sent it on to them.
Jan 21, 2013 | Lanier Office Equipment & Supplies
Can you please tell us where the waster toner bottle is located on a lanier 2145; can't find it anywhere
Hello!
I suppose that it is a printer.
In this printer the toner waste goes to the Transfer Unit.
Open the right door and you will see the trasfer unit. You have to take it out and open it. Then just empty it to a bag.
Take a look at this picture
Jul 21, 2011 | Lanier 1205 Copier
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
How do i empty a waste toner bottle on a lanier color copier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Feb 25, 2010 | Lanier 1205 Copier
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Apr 10, 2009 | Lanier Office Equipment & Supplies
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
Ricoh FT5832 Copier Logo
219 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
