Question about Mach Speed P4M800 (890552603480) Motherboard
What's the normal cpu speed in p4m800 and why my cpu speed is showing zero
  • 375 Answers
There is no 'normal' speed - it depends which CPU you have installed.
Posted on Jun 29, 2009
My CPU Heat
You should check Task MGR and see what process's are running, you need to find out if the CPU is being pushed, when you are not doing anything the CPU should be close to zero or between 0-10 percent.
So if you check and find the CPU is running at Idle, then you check the CPU fan clean it.
You should install software that will show you the CPU temp and fan speed, as you work the CPU through software running, the fan should increase in speed.
If the CPU is not staying cool near 40C, then look for a better cooler.
Thermal compound has no miracle, the cooler is what is important, and the case fan is not as important as the CPU cooler itself.
Dec 02, 2012 | Computers & Internet
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
Nobody has a list of cpu's that will work with p4m800-m7a 7.0
the p4m800-m7a v7.0 will work with a pentium d. I am currently running the p4m800-m7a v7.0 with a pentium d 2.8ghz and it works perfectly.
Dec 08, 2009 | Biostar P4M800-M7A Motherboard
Slow, Slow mobo
Is your CPU set to its correct speed
Aug 18, 2008 | Mach Speed P4M800 (890552603480)...
P4M800-M7
please give me a software copy of motherboard P4 M 800 -M7 A ver 7.1
Jul 13, 2008 | EliteGroup P4M800-M7 Motherboard
Upgrade vga & processor for elite P4M800-M7
Hi kapitan, for starters the AGP is faster than a PCI. Yes, you can upgrade to 512MB. There is a direct path to the CPU when using an AGP video card.
Elite Group has 2 P4M800-M7's. One is version 1.0 & 3.1.
Though both boards are very similar they are different when it comes to CPU support.
When you view the main pages for you're Elite Group P4M800-M7. Look to the left for CPU Supported & click it. I'll list both boards along with their link to supported CPU list. You will need to find the version number (on the board) in order to pick the correct CPU supported per version number.
Link 1, Version Number 1.0
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=531&CategoryID=1&DetailName=Specification&MenuID=7&LanID=9
CPU's supported. V1.0
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=531&MenuID=69&LanID=9
Link 2, Version 3.1
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Specification&MenuID=7&LanID=9
CPU's supported V3.1
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=548&MenuID=69&LanID=9
Depending on the version number you can reach CPU of 3.8MHz.
Hope this was helpful.
Feel free to ask if you need more service.
Good Luck!
Mike
Apr 24, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Open Questions:
How To Fix Laptop That Won't Turn On 'Call +1888784-9316 In case you have encountered certain issues while working on your important project from office or while doing college assignments due the next day and now you are searching for some strong supportive tech support service, then get in touch with the tech support executives of Dataalign. Call Toshiba support for getting rid of all sorts of tech issues whether related to software or hardware. Getting tech issues fixed in a matter of few minutes is the speciality of tech support executives of Toshiba support. These executives of Toshiba are certified professionals and they make proper use of their expertise and years of working experience in the field of customer support for customizing a unique and exclusive tech support service according to the required need of the customer. We can say that Toshiba tech support is the simplest, effective and customer friendly tech service. It has got everything that makes a tech support service high in demand, like being pocket friendly, easy accessibility, available even at the odd hours, courteous and polite support executives. These technicians always try that all the customers they deal with, get satisfactory outcome and also experience friendly customer service. Toshiba laptops are famous around the world for their eye catching features and advanced technical characteristics that make them everyone's first choice. Still Toshiba customers face issues in their devices ranging from minor issues to major ones that can gradually lead to effecting the laptops performance permanently for a long term. Issues that are usually faced by customers are not able to process fast, getting the command keys wrong, screen freezing issue, blue screen of *****, frequent invasion of viruses, Trojans and malwares etc. Toshiba support has been helping customers to get rid of all these issues as soon as possible. Their assistance is available 24/7 through various modes of communication like via mail or through phone. They employ advanced techniques for resolution of issues and they use remote access process for their work which makes is more accurate and faster. Call on toll free helpline number +1 888 784-9316 anytime and get support anywhere. Enjoy the work being done in front of your eyes by asking for tech support service at the time and place of your choice.
Jul 17, 2018 | Toshiba Computers & Internet
See all Mach Speed P4M800 (890552603480) Motherboard Questions
Mach Speed P4M800 (890552603480) Motherboard Logo
122 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
