Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Posted on Jul 13, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
PUT IT IN THE DISHWASHER AND RUN FOR 10 MINS, MINE WASNT WORKING EITHER SO I DID THIS AND IT WORKED GREAT. THE KEY IS TO LEAVE THE SAW RUNNING WHILE THE DISHWASHER IS RUNNING, THIS WAY IT ALL GETS CLEANED, ALSO USE LIQUID TIDE SOAP WORKS BEST
Posted on Jan 07, 2013
I believe the 455 rancher and the 460 are basically the same saw. On my 460 there was a black plastic gear driven by the sprocket that drives the oil pump. The teeth on the gear were mangled. The part was about $4 on line. Oiler works fine now.
Posted on Jul 10, 2009
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husky Rancher 455 is not delivering enough oil to the bar...ports are clean, bar is clean and oil is coming through port on the saw. Brand new chain is now dirty after one tank full. Leak somewhere?...
a few of things here, the pick up pipe can get kinked thus slowing the oil flow down, the filter on the end of the pick up pipe may be partly blocked,if you are using non fling oil and the outside temperature is very cold you may need to thin the oil to allow a better flow, finally you can modify the pump shaft, this is done by increasing the angle on the end of the pump piston ( the bigger the angle the bigger the throw of the shaft and the more oil is pumped ) this is a final resort and has to be done with care, you have to remove the shaft from the pump body and hold against a grind stone to increase the angle
Jan 06, 2018 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
, No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Clutch slipping?
Probably, the interior of the clutch was soaked with oil. Try washing it out with spray carburetor cleaner by removing the cover, chain, and bar. Unless the clutch surfaces were burned from any slipping that occurred, that should restore the clutch. When reassembling, make sure you can move the tightened chain by hand. Check for proper oiling, by running the bar tip at speed in front of a piece of cardboard for several moments-- it should throw off a thin line of oil. Hope this helps!
May 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
06 1500198
Lou
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 chain saw does not seam to be oiling the chain enough,checked an cleaned oiler chain an bar ,i cant find my book but i know it can be adjusted but dont know how
Caution it is probably only a 3 position oiler, forcing it beyond either stop may cause failure. The 2009 om (may not be your saw) adjustment is on page 33 of the Operator's Manual (below).
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
HTH
Lou
Jan 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not oil, replaced complete oiler,
An IPL with oiler components and part numbers can be here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Our job is to provide the knowledge and illustrations available to help you determine which oiler component has likely failed. Your job is to apply that knowledge and make the final determination. If you aren’t comfortable doing that then your only option short of saw disposal is your friendly local chainsaw seller/mechanic. You might be pleasantly surprised at how reasonable they are.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
  2. If no, continue with 2.Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 08, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Aug 23, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
1,886 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
