My jvc Everio GZ-MG21 camcorder is not compatible with windows 7 how can I transfer my video clips on my pc to then put on dvd disc
SOURCE: PC does not recognize the video recordings of my JVC Everio GZ-MG21
Actually if you just change the .MOD endings to a .MPG it should work just try it on a file you have copied but keep the original intact. I also had the same problem with the JVC piece of junk I bought. This is what I found out on the net. It works but I don't know if there is and loss in the process
Rick
SOURCE: How to transfer videos on JVC Everio GZ-MG21U camcorder to DVD
YES!!! I GOT IT!!! Ok so the comp doesn't recognize the damn camera. I went around the problem!!! OOO so excited!!! Ok sooo simple, you'll slap yourself! Ok. First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
Save yourself a lot of frustration. If you have this camera change the extension of the files from .mod to .mpg and it will be compatible with a lot more video editing programs.
SOURCE: no disc for my JVC Everio GZ-HD7U
My Jvc GZ-HD7U will not connect to by PC. I am running Vista. Is there a suggestion?
