Question about Canon CanoScan 4200F Flatbed Scanner
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Posted on Mar 05, 2010
How do I fix TWAIN error? How do I fix Scan Gear error message cannot communicate with scanner?
you need to make sure that your printer is supported by TWIN , you can do that online.
Oct 21, 2015 | HP LaserJet Office Equipment & Supplies
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error while communicating with scanner message
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
Feb 07, 2010 | HP ScanJet 3500C Flatbed Scanner
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Locker
Had same problem with the 'release the lock switch' garbage. Didn't know where the faaaark the sodding release switch was anyway but gave the scanner a good whack on each of the front corners.....problem fixed.
Oct 03, 2007 | Canon CanoScan LiDE 500F Flatbed Scanner
Scanner
If the unit is in warranty, get Epson out to it. If not check the simple things like making sure the head lock is not on. Look to see if the scanner head starts to move at all when you power up the unit. If the head does not move at all or makes an unusual noise, chances are the unit is complaining that the head is stuck or requires too much effort to move it. Other possibilities include a communication error between scanner and main board of the SPC or SPC and your computer - indicates broken connection or bad USB cable. POssibly a fault with the mainboard of the SPC itself. Error ?Cause *Remedy Scanner error ? Lamp has burnt out. * Replace the scanner lamp. ? Power is turned on without unlocking the scanner. * Unlock the CR. ? The scanner carriage is interfering with any other part. * Remove the obstacle. * Replace the scanner carriage unit.
Jun 22, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon CanoScan 4200F Flatbed Scanner Logo
361 people viewed this question
old marine
old marine
