Question about Vehicle Parts & Accessories
I bought a Viper Alarm for my 97 Silverado and the locks work but not my remote start or alarm. It doesn't crank or start the motor the lights just flash and it acts like it wants to work but doesn't. The avital alarm I had before this one worked just fine so I don't know why this one isn't. I appreciate anyone's help.
    New Friend:
  • 36 Answers
Clear the codes on the truck
Posted on Dec 14, 2017
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
Posted on Jan 28, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
My Hornet alarm doesn't chirp, activate, or go off anymore. I've tried to check the valet mode, but it doesn't do anything. The remote still locks and unlocks door's and it cranks.
My car alarm doesn't chirp all the time, but it still unlocks the ...
forums.anandtech.com > Social > Off Topic
AnandTech
Feb 3, 2003 - 11 posts - ‎7 authors
My car alarm doesn't chirp all the time, but it still unlocks the doors. ... Distributed Computing. ·, Security. ·, Social. ·, Off Topic ... The rest of the electrical systemseems fine. ... Just read the owners manual and find out to to re-enable the ... but like when I arm my alarm it arms but then it'll go off for no reason.
Alarm Troubleshooting Help Tips - Dr.Detail
www.drdetailshop.com/TROUBLE.html
When you try to start the car the alarm goes off.. It could be your battery. 3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery ...
Viper Alarm won't chirp help!! - 12 Volt Forum : Car security ...
www.tintdude.com > ... > 12 Volt Forum : Car security / Convenience
Sep 11, 2006 - 7 posts
posted in 12 Volt Forum : Car security / Convenience: Hi I am new to this site ... Myproblem is when I lock it it won't chirp or roll my windows up ... If I hold the lock button the siren will go off,and if I press and hold the AUX my windows will go down. ... It won't chirp when activated or when I hold the arm button.Missing: hornet
How To program DEI Viper Python Avital Sidewinder Valet ...
? 3:34
https://www.youtube.com/watch?v=r01ntAXGxBw
Mar 10, 2011 - Uploaded by Lessco Electronics
hi I have the viper 7142v alarm system,tge problem is I only had one remote,I ordered a spare but ... My alarm only chirps when i am programming lock and unlock functions. it does not ... As soon as I connect car battery my alarm goes off. ... I obviously don't have a remote, and it doesn't have a valet switch.
Jan 06, 2016 | Vehicle Parts & Accessories
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Jan 28, 2014 | 5301 LE 2 Way Car Remote Starter System
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Just got my viper 5701 yesterday and the auto start on alarm worked perfectly. I woke up this morning and the auto start would not turn motor on. locks worked and everything. Took it back to dealer they...
The buzzing noise and lights blinking 5 times is part of the "Find my Vehicle" feature. This usually happens when/if you press the button too long. It takes a little getting use to, but keep practicing pressing the Remote Start button down for only a second or less... you should be releasing the button almost immediately after you hear it make the confirmation tone (meaning the vehicle has received the signal to start). If this doesn't help out, then you may need to go back and talk to your installer about trouble shooting!
Dec 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Hello, I have a Viper 5701 in Mazda 3 2006 several times my car car did not start when I crank it, absolutely nothing happens. The same thing happens if I open my car with factory remote and try to crack...
What type of transponder bypass was used? You will need to check with your installer. You will want to know if the data bypass module is coming ON upon remote starting. And NOT coming on during regular starting.
Aug 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
