Question about Garden
When my echo trimmer is tilted forward it stops running, whats wrong with it?
  • 154 Answers
Not getting gas
Posted on Aug 03, 2009
Echo SRM225 line trimmer continually feeds line
If the line feeds with out bumping it nay be the line gas been put on the wrong way
Apr 30, 2017 | Echo Garden
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
M echo trimmer isrunning half speed
Start with one full turn out on the low side and the high side, then set your idle.
Aug 26, 2014 | Echo Garden
I HAVE AN ECHO 200 WEED TRIMMER. THE ENGINE RUNS, BUT DOES NOT TURN THE TRIMMER? CAN YOU PLEASE HELP ME.
hello tman.. when the engine runs but the trimmer does not turn it generally means that the slender drive shaft that runs from the engine to the trimmer is broken and must be replaced. Good news is that Echo tools have a 5 year warranty so find an echo dealer and he will fix it or replace it if it is less than 5 years old. joe
May 29, 2011 | Echo Garden
I HAVE ECHO TRIMMER THAT JUST SEEMS TO RUN LIKE DOG,HEAD SPIN VERY SLOW,WHAT IS BEST TO DO TO IT ?
If the engine seems to be running properly, you may have something that is binding the head or shaft. Check those places and see if that helps. Good luck...Lee
Aug 29, 2010 | Echo Garden
Cleaned carb on echo headge trimmer how do i redo
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
Oct 24, 2009 | Echo Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
