Question about Smith Corona Wordsmith 200 Typewriter
I just unpacked and set-up a new WordSmith 250 and I can't get the paper to feed in. The paper isn't held tight enough to the platen to pull the paper in using the side knob. I have tried re-positioning the the paper release lever to no avail. Am I missing something or did I get a dud?
  • 478 Answers
The tension spring has probably come loose I can e-mail you a copy of the platen removal and replacement page from the repair manual
Posted on Nov 15, 2007
Green light for paper feed isn't on and paper won't feed
paper start sensor is not functioning properly. clean it or replace it.
Jun 16, 2011 | Canon imageRUNNER 2200
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Paper feed Ricoh Aficio 1015
Is the copier not feeding? There are many problems that could be causing this.
- The feed roller could be dirty or worn. The feed roller sits on the upper right side of the paper tray -- it's a thick gray roller. Clean this roller with a lint-free rag and some alcohol.
- The paper fences might not be tight. There are two paper fences (one toward you and one on the far side of the paper, away from you). Make sure these fences are tight enough so that the paper does not move around in the tray, but not too tight to keep the paper from being fed out of the tray. Also make sure the green guide on the left side of the paper is snug but not too tight.
- The paper could be damp, curly, or full of static. Damp paper is a big problem, especially in the summer. Try filling the tray with a fresh **** of paper and see if it feeds through better. Also make sure none of the pages in the tray are bent or folded under.
Did any of these suggestions help?
Aug 28, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
Copier will not feed from paper tray
check he direction of the paper in the tray to see if it maatches that on the display then make sure the paper guide fences in the tray are set correctly and that they are tight on the paper edges and the paper isn tloose in the tray.. as a last check you can take the paper tray out and make sure there is no paper stuck inside and if yoyu get a clean cloth and a little glass cleaner on it you could try and rub eh feed rollers to see if they are dirty as this willl often cause miss feeds.. Good Luck A ,,, let me know if you need more info
Jul 01, 2009 | Ricoh FT3713 Copier
Have just installed a new HP Deskjet D4360 Printer. Everything is correct except that the paper-feed is not working and although there is paper in the printer an on-screen notice says 'Out of paper' The...
Sounds like you may have too much paper in there. Try just puting a few sheets in, turn it off and turn it back on and see if it doesn't load. Also check internally on the printer, if this is a new printer that you jsut unpacked there may be tape or something inside the printer (like where the toner goes or in the paper drawer.
Apr 30, 2009 | Office Equipment & Supplies
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Smith Corona 240 DLE
pull the paper release lever and look under the platen as well as you can, to see if there are any forien objects. check if the feed rollers are all in place. the slots in the paper pan under the platen should have rollers in them
Jun 26, 2008 | Smith Corona Wordsmith 200 Typewriter
No paper feed
what is the printer brand and model#? also try making sure the paper is in far enough and isn't sticking, and the paper guide is tight
hope this helps
Apr 09, 2008 | Office Equipment & Supplies
Paper does not feed
Try to adjust your margins in the paper feed tray, chances are they are too loose. Do not space your margins too loosely or too tightly, just enough for your paper size to fit.Also check if your paper thickness is setup for boards or thicker paper types.
Mar 08, 2008 | Canon i860 InkJet Photo Printer
Paper will not feed
> Epson replaced the printer.
I think that you have been "unlucky" to get a replacement-printer with the same problem as the first printer. Get them to replace it, again.
Check that there is nothing "extra" inserted into the printer to stabilize the moveable parts during "shipping" -- such "padding" must be removed before using the printer.
Oct 18, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Smith Corona Wordsmith 200 Typewriter Logo
218 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
