Question about Kenmore 45062 / 45069 Electric Kitchen Range
I have a Kenmore 30 inch drop in oven. Model 911.4558813. The oven will come up to temp and stay for a while. Then it will shut down for no apparent reason. If you Bake again it will turn right back on.
  • 999 Answers
Shut down as in turns off or just refuses to maintain temperature? If the control is resetting to off there may be a loose or broken power wire going to the control board. If it just quits heating the sensor or a relay on the relay board is the culprit.
Eric
Posted on Jun 29, 2009
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
Kenmore oven model #9119359181 oven temp will go
check heat sensor. probably needs to be replaced
Dec 01, 2009 | Kenmore Kitchen Ranges
I have a GE 30 inch drop in range. Oven temp will beep and read F3 and shut off. It can be turned backed on and sometimes it will stay on and sometimes it will go back off. Oven temp is also off.Had...
When you reach this point, buying boards is risky since they are not returnable. Best bet is to yank the range and replace it. You'll be dollars ahead in the long run.
Oct 29, 2009 | Kitchen Ranges
Oven temp doesn't stay constant
your clock/timer control board controls the oven. the switches control the top. if connects were a problem until you moved them to a certain position then replace ends. but your problem with the temp. is gonna be fixed by replacing your control board.
Jun 19, 2009 | Kenmore Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 45062 / 45069 Electric Kitchen Range Logo
403 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
