I get the following error message when trying to write cds... sense key=unit attention sense code=0x29 POWER ON, RESET, OR BUS DEVICE RESET OCCURRED
  • 13,433 Answers
Whats the brand and model of your device?
Sounds like the cd drive is failing, and the burning process caused it to re-start. it could be another problem also.
Posted on Jun 29, 2009
Resource Conflict - PCI on Motherboard. Bus:08, Device:09, Funtion:00 / 01 / 02 / 03 / 04
well basically there is something wrong with the system a bus on the mother board is malfunctioning ,well try reinstalling the windows that would usually start the system completely over
Jul 02, 2013 | HP Computers & Internet
When printing, lines are not evenly aligned. This is a recent problem as the printer has worked beautifully for years. Is there a way I can adjust this?
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem.
Sep 16, 2011 | HP PSC 1210 All-In-One InkJet Printer
13.20 error problem
Or
4. Release GO.
Sep 16, 2011 | HP LaserJet P4014n Printer
MFC 5440cnz I get ''unable to clcean message'' have unplugged it and restarted cimouter, but still getting message
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 10, 2009 | Office Equipment & Supplies
Error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Oct 28, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to print see troubleshooting and routine maintainance in users guide Have read through guide, followed all instructions,cleaned, replaced cartridges , turned off at main supply AND still same...
Oct 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
I suddenly got an LCD Error E000 in the middle of copying. I have followed the reset procedures outlined by Canon. I have powered it off for up to an hour but still get the error messages. I have reset...
Make sure it has its own dedicated power and not sharing power with any other device. If the power checks to be good, follow the steps below.
Perfrom a Printer Reset. A Printer Reset can be done by:
1. Enter Service Mode by pressing the ADDITIONAL FUNCTIONS key, then the # key.
2. Scroll through the menu using the arrow keys to the left or right of the SET key.
3. Find #7PRINTER and press the SET key.
4. While in the the #7 PRINTER menu, use the arrow keys and find #4PRINTER RESET and press thre SET key.
5. A selection of either YES or NO will appear, use the arrow key to the LEFT of the Set key to select YES.
6. After YES has been properly selected, unplug the machine and plug it back in.
Following these steps can reset this code.
Oct 20, 2009 | Canon imageCLASS D860 All-In-One Laser...
What does this mean?
there might be a hardware problem on your device
Jan 09, 2009 | Computers & Internet
CD ROM not working
from microsofts site:
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard
Dec 26, 2007 | Acer Aspire™ T180 PC Desktop
More Error Codes
Try a lens cleaner - but yes time to put it out to graze I would imagine
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Computers & Internet Logo
David Payne
David Payne
