Question about Karcher 2500 PSI Pressure Washer
After running about 30 minutes the pump forces engine to stop.
When I fire up the washer it pumps ok but after about 30 minutes the whole system grinds to a halt. Engine shuts off.
bestdarngood
  • 3037 Answers
SOURCE: karcher 2400 pressure washer with
The pump is correctly oiled and lined up on the camshaft, correct?
Posted on Jul 20, 2008
  • 33 Answers
SOURCE: pump on my pressure washer will not pressuerize
there is a loader and unloader valve on your pump bolted to it. if it frozen in the open position it will never build press. most of the time this is caused by leaving cleaning solutions in system after use and let set up for a long period. it causes the aluminum case to corrode.;you will have to dissassemble and clean if not to bad. if not your going to have to replace.
Posted on Apr 21, 2009
  • 92 Answers
SOURCE: My 24o0 pressure washer pump has failed. Unbolted
Dear 1tindy,
You asked what the trick is. Well it is a trick, and in fact a big hasle. When a pump has failed it is never removed from the engine or from rhe electric motor(if electric motor driven.). To service the pump only the head and its components must be removed. When these are removed and the oil drained, you see a swash plate that is held down by a bolt. The swah plate could also be fitted by force fitting. After the swash plate there is an oil seal then a bearing. So if for a reason you must remove the pump from the engine you must do all these steps. In a few words....Remove head, remove piston holding head, drain oil, remove swash plate and finally the pump can be pulled away, but with some force,..because there are bearings. I wish to repeat that if the engine has no trouble, do not remove pump from engine. Just service or replace parts of the head of the pump.
Regards,
Fulltech.
Posted on Apr 23, 2009
SOURCE: honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
Posted on May 07, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
I have a amana washer my drain line was froze. but now the lights don't come but i can hear the pump huming. Could the pump be froze or is there a reset button I don't know about?
If the lights are not coming on, but you hear the pump, it could be stuck in the force drain mode. Let it run for about 2 minutes and see if it stops on it's own. If it does stop, try putting the unit into a regular cycle, if it lights up, you should be ok. If the pump does not stop, and lights are out, replace your control board. Make sure you follow recalibration instructions for machine to work properly.
Feb 15, 2015 | Amana NTW4650YQ Top Load Washer
Engine dies when hot fuel not pumped round the system kohler 18hp
If the engine has a black pump on the side of the engine it may be faulty, there is a diaphram inside, but the pump is non servicable, it takes a pulse from the cylinder head or rocker box, this pulses the diaphram, which then pumps the fuel, as there is no gravity feed from the tank, it requires the pump to fill the carb.
May 19, 2012 | Garden
2000 v w 2.0 starts fine but goes dead immediately
If the engine cranks and fires, then runs for about 1 to 2 seconds, look for a 'Yellow Car' symbol in the cluster.
This indicates the ECU does not recognize the key transponder and denies a engine run command.
If this is not the case you may have a faulty fuel pump. Fuel pumps fail and just give a short pressure rise before they quit allowing the engine to get enough fuel to fire but not run.
Another problem with these is the oil pump. When the engine fires it runs the oil pump and if the dump in the oil pump is faulty, it builds too much oil pressure and forces the valves off the seats and compression goes away and engine stops.
High Oil Pressure ( Over 90 psi.) overpowers the hydraulic valve adjuster elements to the point they pump up holding valve slightly open.
Only cure is a new oil pump. It lives in the oil pan and is easy to service. Average time to change out would be 2 hours, unless you have a Cabrio, in which case lower shield needs removed adding another 30 minutes to an hour to the job.
Feb 17, 2011 | 2000 Volkswagen Beetle
Navigator leaking coolant
Check you to see that you don't have loose or leaking cooling hoses, a bad radiator cap, a loose radiator drain plug, or a failing water pump.
If all these are OK, put a bottle of BAR's radiator stop in the radiator and run the engine in idle for 15 to 30 minutes. Available at your local auto parts store.
If your leak is not to serious, this should fix the problem. Put a bottle of radiator stop leak in your cooling system and repeat the procedure once every six months, to lubricate the water pump and keep leaks sealed.
May 26, 2010 | 1999 Lincoln Navigator
96 ford f150 5 l engine, replaced pcm twice, replaced whole distributor, tested ecc and cps. Fuel pumps tested. Still won't get fire to plugs or run fuel pumps
ecc and fuel pump relays good? when the engine is turning over, does the ck engine light go out? if not the PCM isnt getting a crank sensor signal. Power and grounds all ok at pcm?
Oct 07, 2009 | 1996 Ford F150 Regular Cab
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
May 04, 2009 | Northstar Pressure Washer 3000 PSI
No pressure from pressure washer
The "dump valve" inside the units pump,not engine is more than likly malfunctioning or bad. Try checking pump oil,buy 30 w pump oil and fill to line also ckeck black cone type turn knob marked +/- and turn to + for increase in pressure,also check water supply hose and if restricted ,unrestrict water line.
Please rate jj505
Apr 02, 2009 | House Brand Garden
1999 toyota tacoma Sr5 won't start
Check for fuel pressure when starting. Fuel pumps have a check valve in them that keep fuel in the rail at the injectors. If the check valve fails, the pump has to pump fuel all of the way up to the engine. Same thing with hot no-restarts. Fuel pump.
Aug 08, 2008 | 1995 Toyota Tacoma
Karcher 2500 PSI Pressure Washer Logo
73 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
