Question about Proscan Televison & Video
NO SOUND OR PITCURE. SOUND WENT FIRST,THEN PICTURE WENT IN ABOUT 5 MINUTES
  • 13,433 Answers
In most cases its a technical problem inside, sometimes it may fix it self by unplugging it set for a hour or less maybe more.
The mainboard will probably need some components replaced ones a professional finds the problem from it.
The speakers and the screen itself are most likely in good condition, its on the circuit boards. Your going to need to get the tv looked at.
Posted on Jun 29, 2009
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
No pitcure but sound works
HI
Make sure that all cables are where they should be, as well as the scart plugs. If that does not work disconnect the TV, wait for 2-5 minutes then connect to the electricity again and start the show. This usually works for me. If you do not succeed the first time try again an hour later.
Good luck
Kolbrun
Feb 15, 2012 | Televison & Video
When tv is turned on it takes 35 minutes for the pitcure to come on, like it is warming up. It is a flat screen digital tv and only 3 years old.
u have to replace apart inside the tv (picture tube base)
which connects picture tube to circuit board,,, call aservice pro...the symptoms are blurry picture & after some time picture gets clear
Apr 02, 2010 | Bush 5693D 24" TV
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
Jul 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
My 60" philips tv
sounds like the LSB board, which is a common fault with your model. You can get a new DPTV 300 series LSB at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Philips 60PP9202 60" Rear Projection...
Toshiba problem
did you try power reset leaving unpluged for 5 minutes
it might be the power house component went out
do u get sound at all
this might be indicator of bulb replacement if no picture but sound
May 09, 2008 | Toshiba 57H81 57" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Pitcure no sound
Try unplugging the set for a munite and check the internal/external switch on the back if this model has one. If sound is not restored you have audio circuit problems
Oct 14, 2007 | RCA P60921 60" Rear Projection Television
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
35 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
