Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Paper Jam, at roller applying toner but not set yet, so when I remove paper, ink on it, but still powder. Thank you! (Debating if to sell if repair not worth it.
    Scholar:
  • 141 Answers
Probably have a broken fuser drive gear. Very common. Try removing the fuser. Large gear on right (rear) end is probably broken.
Posted on Aug 04, 2009
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Tip
Paper Pick up problem
All printers are bound to encounter a paper jam. <br /> <br style="font-weight: bold;" /> <span style="font-weight: bold;">Symptoms:</span><br /> There are rollers to pick up paper and roll it to print head and by time dust from environment and paper coats those rollers and applied pressure makes it slide. The same dust also clog paper sensors so printer thinks it got either no paper or paper jam.<br /> <br /> Another reason for jams are foreign objects (paper clips, food, etc..)<br /> <br /> <span style="font-weight: bold;">Precautions:</span><br /> Please note that all procedures mentioned here are to be done while <span style="font-style: italic;">printer is off</span> and don't forget that laser printers <span style="font-style: italic;">use heat </span>so be careful while touching printer objects. <br /> <br /> For any reason, if you're hands are contaminated with ink or toner, clean them well. <br /> <br /> <span style="font-weight: bold;">Action:</span><br /> Follow manufacturer instructions regarding both paper type and maximum paper capacity for the tray.<br /> By Turning printer off, open or remove paper tray and/or printer door to access toner or cartridge and remove any visible foreign objects (remove toner cartridge in lasers). Don't forget that if paper is visible in one piece, <br /> pull it slowly with both hands on the corners.<br /> <br /> In case of <span style="font-weight: bold;">paper out</span> message and no visible paper, it's time to clean paper sensor(s) by blowing some air from a pressurised source.<br /> <br /> On the other hand, you may clean paper rollers with a slightly damped lint free cloth by rubbing. This procedure may solve paper pick up problems.<br /> <br /> If all of this didn't work for you, perhaps its time to contact service.<br /> <br /> Good luck and happy printing.
on Nov 25, 2010 | Office Equipment & Supplies
Tip
Paper Jams
All printers are bound to encounter a paper jam. <br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Symptoms:</span><br />There are rollers to pick up paper and roll it to print head and by time dust from environment and paper coats those rollers and applied pressure makes it slide. The same dust also clog paper sensors so printer thinks it got either no paper or paper jam.<br /><br />Another reason for jams are foreign objects (paper clips, food, etc..)<br /><br /><span style="font-weight: bold;">Precautions:</span><br />Please note that all procedures mentioned here are to be done while <span style="font-style: italic;">printer is off</span> and don't forget that laser printers <span style="font-style: italic;">use heat </span>so be careful while touching printer objects. <br /><br />For any reason, if you're hands are contaminated with ink or toner, clean them well. <br /><br /><span style="font-weight: bold;">Action:</span><br />Follow manufacturer instructions regarding both paper type and maximum paper capacity for the tray.<br />By Turning printer off, open or remove paper tray and/or printer door to access toner or cartridge and remove any visible foreign objects (remove toner cartridge in lasers). Don't forget that if paper is visible in one piece, <br />pull it slowly with both hands on the corners.<br /><br />In case of <span style="font-weight: bold;">paper out</span> message and no visible paper, it's time to clean paper sensor(s) by blowing some air from a pressurised source.<br /><br />On the other hand, you may clean paper rollers with a slightly damped lint free cloth by rubbing. This procedure may solve paper pick up problems.<br /><br />If all of this didn't work for you, perhaps its time to contact service.<br /><br />Good luck and happy printing. <br /><br />
Please help me with printer jam
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you get toner or ink on your clothing, wipe it off with a dry cloth and then launder the clothing in cold water.
Watch out for loose toner or ink on jammed paper, and do your best to avoid spilling it on yourself or the printer. If a little bit of loose toner or ink gets in the printer, though, it should clear after a few sheets are printed.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
IT KEEP SAYIN RMOVE PAPER JAM
    Remove any paper trays. Inspect them for wrinkled or damaged paper.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  2. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though
    1. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
May 02, 2010 | Office Equipment & Supplies
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 16, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper jam
First I would request you to provide the name and the model of the printer which would helps us to provide you more specific troubleshooting steps for your type of printer. I am providing you some of the trouble shooting stpes which should be ideally done in cases like papaer jam:
* Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
* Turn off the printer.
* Remove any paper trays. Inspect them for wrinkled or damaged paper.
* Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
* If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
* If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly . The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
* If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
* Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
* If the printer paper jam message still appears, then there is still some paper in the printer.
Hope this would resolve the issue.
Thank you for contacting Fixya.
Jul 10, 2009 | Office Equipment & Supplies
Epson stylus cx6600 alll in one roller crimps and stops paper from rolling. My computer says it is working properly. It all started with a paper jam, which I cleared, hit "color" and thus my problem.Ally
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jul 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper jam
reset by unplugging and then plugging back in, also make sure no paper is stuck in the rollers on top or the back....make sure all rollers are free of dust and if they have dust wipe off.....make sure you using the right type of paper and the printer itself isn't dirty....hope this helps
Apr 06, 2009 | Brother HL-2070N Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
