Question about Coleman Powermate Powermate 5000W Generator
Tecumseh hm100 powermate generator won't stabilize.Starts easy,not many hrs. on it,just run it once a month for about a half hour and it always took around 5 min. to smooth out.Gas and plug are good,took the bowl off and made sure all was clean.
  • dcampagnone1 Jun 30, 2009
    ...air filter was fine...plug gets black though..
    President:
  • 1,714 Answers
Check the air filter.
Posted on Jun 30, 2009
Tecumseh hm100 leaks oil day after using.found oil leak around plate underneath eng,i tried tightening screws no help.can i remove this plate to check for a gasket leak?
You could do this but leak could also be around oil filler plug if not seated. The main engine bearing seal is more likely if the unit is old with large number of hours.
If you find a bad gasket, replace with the silicone make your own sealant AND DO NOT overtighten screws. That can worsen the problem with gaskets.
Jul 04, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
I have a 4000 watt coleman powermate that is fifteen years old and approx 200 hrs on it. Had it running during a blizzard and the motor pulled down and now only puts out half power.Could swirling snow have...
Yes, swirling snow could have done some damage. Any snow that may have gotten inside had enough heat to melt it but not evaporate it. It would be overly difficult to try and explain how to take it apart over the internet. I would suggest taking it to a small engine repair shop. Is it running at full rpm with half the power or running at half the rpm at half power?
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Feb 01, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate 5000W generator Tecumseh HM100 159409P
I recommend that you purchase your air filter at -
tewarehouse.com
They offer the lowest prices that I have seen and it is good quality.
Apr 23, 2009 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
735 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
