Question about Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Wolf Range r366 - How do I replace the igniter
Wolf Range r366 - How do I replace the ignitor? One of the igniters is firing intermittently.
I have a Wolf Gas Range and initially my igniter incessantly sparked. I noticed that the igniter is cracked. Do I need to replace it and if so how do I replace it? The electrical wire to the igniter became disconnected; should sticking it back into the igniter cause it to work?
Posted on Oct 16, 2009
Wolf broiler will not light
defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately
Feb 13, 2018 | Wolf Range Kitchen Ranges
Oven will not ignite; takes several minutes when it does; gas is available (can smell it)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 06, 2011 | Wolf Range 30 in. SCB30C Gas Cooktop
The igniters on my Five Star TPN535-BGSW Dual Fuel Kitchen Range don't stop after the burner has ignited. This is a long time intermittent problem that effects the most used burners but not the least used....
Most likely one of these two causes:
1. Corrosion or build up on one of the metal surfaces that provide a path to chassis ground from the ignitor through the burner and frame back to the chassis ground connection to the spark module.
2. An intermittent spark ignitor wire or corroded connection to the ignitors.
There is a 3rd possibility if the range has been worked on ...
Turn on all the burners, if the sparking stops then the problem is that two or more of the ignitor wires have been swapped between burners.
Jun 27, 2010 | Five Star TPN535-BGSW Dual Fuel (Electric...
The broiler wont work
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 22, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
Grill won't stop ignigting
See if the thermal bulb is in the flame, if not gently bend the bulb so that it is in the flame if that does not solve the problem you will have to replace the bulb to the igniter.
Jun 14, 2009 | Wolf Manufacturing Gas Kitchen Range
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Gas Range, trouble igniting
It is likely that the ignitor needs to be replaced. If the range does not sense the correct amount of resitance in the ignitor it turns the gas valve off. When the ignitor is starting to fail the problem is intermittent, so the range turns on and off as you have described.
Dec 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Wolf Range CHR-0-29-FT34 Gas Kitchen Range Logo
2,720 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Steve F
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
