Question about HP Pavilion dv9000z Notebook
Location of restart button
My Notbook has hanged so i am just searching for restart button. Can you please tell me where i can find restart button in DV9000 series
Re: location of restart button
The reset button is the on/off button you have to hold it down for atleast 10 secs.
Posted on Aug 07, 2008
  • 23 Answers
If all else fails, have tried unplugging it and taking hte battery out?
Posted on Nov 07, 2007
0 characters
3 Points
Veriton l410 bios
Could be bad RAM, motherboard, hard drive, etc. Any beeps during startup? They would tell you what is wrong (with a Google search).
Mar 24, 2014 | Lenovo PC Laptops
My pointer froze ,dont want to move
It seems that the OS hanged,
If You have external usb mouse, try it.
You can restart the OS again,
Please tell us your results
Good Luck
May 13, 2011 | PC Laptops
No caming my notbook bluetooth
try restarting it
if nothing happens you need to format it
Nov 25, 2010 | Dell PC Laptops
I have installed all the T60 drivers, chipsets, including Ati video driver and display and presentation driver but in device manager it still says the video controller driver is not installed?
It needs the vga drivers installed. If you have the motherboard cd, follow the instructions as follows; Right click on the "Video Control <Vga compatible>" Select "Update Driver" Select the button "No not this time only" (if you don't see this, skip to next step) Check "Include this location in the search" and click "Browse" and locate the vga or graphics or display folder in your cd directory (folders in your cd-rom) When you have selected the correct location, you'll be able to click "Ok" & "Next" you may get a warning message, just click "continue anyway" or "yes" whichever keeps you moving and it'll automatically install the driver, please note that when it's done, you'll be presented with a message "Restart now" or "restart later" you can select whatever is best for you. If you select "Restart now" the system will automatically restart itself and the problem will be fixed. In case if you don't restart, the changes in the display will take affect until you restart your system. Just wondering did you download ATI Radeon...or Catalyst? Might make a difference if you don't have the CD.Good luck.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
Oct 26, 2010 | IBM ThinkPad T60 Notebook
I have one notbook laptop of toshiba company. the
Hi chivas adars
go to the Toshiba support web page and enter all the details about your notebook, then you will get a list of all the relevant drivers.
Here is the link to get you there:
hope I could help you with this
Oct 21, 2010 | Toshiba Satellite Pro A120186 Notebook
check for upper and lower filters in registry. path is HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then restart pc
Jun 15, 2010 | HP Pavilion dv6000z Notebook
Laptop bluetooth not found
1 > Please check for the product specification whether does notbook has integrated bluetooth Device
2 > Load the Bios Default setting by entering into the BIOS
Steps are
> As soon as on the notebook keep tap on the F10 button
> Press F9 to load the BIOS Defaults
> Press F10 to save and Exit from the BIOS
3> Check for the Wifi Button on/off status
4> In Device manager check for the Bluetooth Device
5> Check in the safe mode for the Bluetooth Hardware in the Device manager.
select Mycomputer-Right click select Manage - Device manager - Bluetooth
To access the safe mode steps are
Restart the system Keep tap on F8 key
In Advanced startup option Select the Safe mode with Net working
Apr 12, 2009 | HP Pavilion dv6000z Notebook
Toshiba Satellite A10-S403d PC Notebook
Computer passwords In the CMOS setup locate the password section and enter, change or remove the password.
Good Luck, Please dont for get to Vote/Thank you
Dec 18, 2007 | Toshiba Satellite A10-S167 Notebook
Window's will not load... desperate need of help
Try this, hook up an external monitor to this PC, usually the F8 key allows you to enable the port to extend video to an external monitor, it varies on each PC. Either way try an external monitor see if the image comes up on that. My suspcion is that the Backlight for the LCD monitor is bad and needs repair. Get back to me please. I would like to no... I am pretty certain that is the case here!
Nov 26, 2007 | Panasonic Toughbook 48 Notebook
HP Pavilion dv9000z Notebook Logo
121 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
