Try here
http://www.cisco.com/web/consumer/support/modem_DPC2100.html
or
http://www.simplehelp.net/2006/07/17/cable-modem-troubleshooting-scientific-atlanta-dpc2100/
SOURCE: Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
SOURCE: I can not detect wireless network
(1)upgrade your wireless phone to 5.8GHz
(2) use a corded phone
(3) use awired internet connection to your router.
SOURCE: i want to connect a Scientific-Atlanta WebSTAR
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication
to establish Internet connection for end-users. MAC address is a unique
identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone
feature of the router. MAC Cloning is a procedure which enables a
router to copy the MAC address of the computer that's registered with
the ISP.
To setup a Linksys router with Cable connection you need to perform
four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
SOURCE: Connect Netgear Wireless Router mr814
Follow the instructions from the installation manual--> copy/paster this link to your browser navigation bar and press enter >> ftp://downloads.netgear.com/files/MR814_QCard.pdf
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
SOURCE: I have a Belkin N150
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
