Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
Fridge and freezer not getting cool enough
I just talked to a technician on the phone and he told that the @ copper lines coming out of the compressor, that one should be very cold and the other should be very hot. Is that correct?
  • 27 Answers
Yes, the larger line should be cold and the small one should be hot. Handle the small one with care, depending on how much load the fridge is under it can get very hot.
Posted on Jun 30, 2009
Smeg fridge freezer FA421XS not cooling
There is copper lines by the compressor it sounds like its low on freeon the cooling chemical you can purchase a kit and weld a valve on the in line and load it up with more freeon that may work
Oct 12, 2014 | Smeg FA421X Top Freezer Refrigerator
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Freezer & fridge not cold enough
Please check the Thermostat switch settings. Try to put it to max cool and then see the results. If it still does not cool the you have to check the refrigent. It is lee and leaking somewhere. Get a technician and get it charged up.
May 18, 2011 | Freezers
The water pressure is very low for the water spout. I replace the filters every six months or so and the place where I buy them told me that the pressure should be a lot higher when a new filter is...
I very much changing the line from copper to plastic will do anything in regards to pressure. You may want to check the fridge inlet water valve though as that may only be partially opening up provided you know the water pressure is normal coming into the house.
Sep 07, 2017 | LG LFC21760 Bottom Freezer French Door...
Amana BRF 20. I know there is a problem when the fridge part is getting warm. The first time, we called a technician and he told us that we had ice build up in the bottom freezer part, at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost timer/control board is bad...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Refrigerators
Ice maker is leaking water into the freezer
There should be a shut off on the copper line .cresent wrench
Nov 24, 2017 | Refrigerators
The water coming out of the water dispenser in our GE Profile PSC25PSWA fridge is hot--hot enough to take a bath in. We don't know why the water is suddenly not being cooled and think this is causing...
Is this a new fridge that was recently installed? Because the only thing I can think of that could be causing hot water coming out of the water dispenser is either the installer/tech hooked up the fridge water inlet line to a hot water line somewhere.
Either that, or there is so much extra plastic water line running around in back and/or bottom of the fridge, that the water in the line is getting heated up by being in contact with the condensor coils or the compressor, etc.
No doubt, this is an interesting situation and some more background will likely be needed to get to the source of the problem, especially since you didn't mention any problems with cooling in the fridge or freezer.
Hope this was Very Helpful and let us know some more info, if my basic hunches aren't the problem. Best regards!
Aug 21, 2009 | GE Refrigerators
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
