The garage door is 15 years old was working well until the battery in the opener was changed and the small code levers inside near the battery caverty were bumped out of place and the order they should be in is now unknown
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
http://www.liftmaster.com/consumerweb
SOURCE: Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
SOURCE: my chamberlaain security + garage door openers
well your main PC board inside of the opener head could have lost the frequency, or the unit memory has been erased, try to reprogram the remotes by going to the back of the opener head and locating the "learn" button which is either red, green, or purple in color. press the learn button then ONE button on ONE remote, pressing multiple buttons or pressing both remote buttons at the same time will not allow them to be programed successfully. after programing test by pushing the same button you just programmed, repeat for other remotes, and if this process did not work than you will need to contact chamberlain
