Question about EA - Electronic Arts The Simpsons Game for DS
Where is it?
Where is the ash tray? i can't find it anywhere, it's nowhere to be seen! please help me.
It wasn't me who solved it, it was my cousin and i'm not sure how she did it.
Posted on Jun 30, 2009
How to replace 95' chevy sub ashtray spring
First thing we need to do before anything is to remove the little feet that the ash tray sits on when it is open, and bend their tabs out of the way so we can open the ash tray to its fullest open position.
To do this, you'll need to play contorsionist a bit, and pull out the little rubber pads from behind the ash tray, then carefully bend the tabs back into the side wall of the ash tray assembly. You can refer to my pic below to see which tab I mean -- And you can also see the remains of the rubber foot in the background .
Once both of these tabs have been bent out of the way, you can then take the ash tray door, and pull it down towards the floor as much as you can.
Doing this will expose a small pin head sized hole in the side of the ash tray, and also a rounded triangle in the sides of the assembly housing, with a small notch at the top. The springs sit inside of these four holes / notches.
Ok, so now that you've got your springs ready to go, its time to install them. You want to take the end of the spring that has a little bit of a bend to it, and slide it into the hole. This will keep the spring from falling out in a few seconds. Once you've got the springs into the side of the ash tray, you'll want to take a skinny screwdriver, and use it to push the spring up and behind the ash tray where you can grab it with your finger.
Then both slightly close, and move the spring into it's proper slot at the top of the triangle. Repeat for the other side, and close the ash tray. It should hold itself shut, if not, make sure that you've got the coils of the springs oriented towards the firewall.
After you've got that finished, then bend the little tabs for the pads back to where they were, and re-install the little pads. You're good to go!
We Are Here To Help !!!
__________________
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Sep 02, 2014 | 1995-1997 Chevy Suburban Ignition Starter...
Replace old ash trays with new ones on rear door panels
Any salvage yard should have a few cars to get them out of, they usually are like new.
Jun 02, 2012 | 1999 Lincoln Town Car
Where do you plug a scanner to diagnose a problem in a 1996 Honda Accord
The obd 2 port in my '96 Honda accord ex is behind the ash tray, you have to take out the ash tray to get to it. Hope this helps! :)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | 1996 Honda Accord
Replace light bulb under dash that shines on console and ash tray
remove the ash tray,then remove the screws that hold
the ash tray bracket in place the bulb will be very easy to change then.
Jan 07, 2010 | 2001 Dodge Dakota
A4 2007 coin fallen behind ash tray,can undo ash try but will not come all the way out and will now not go back into place, any help
You will probably end up having to break the ashtray to get it out. This happens on most cars when ppl use the ashtray as coil holders. Just pull really hard and rip the tray out, see if you cause any damage. Sorry, but this is the only way ive done it in the past.
Aug 17, 2009 | 2007 Audi A4 Convertible
Radio code needed for Chrylser neon 03
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Mar 26, 2009 | 2006 Chrysler Neon
Need to get the cd player out of 03 santa fe, the easiest way ?
Hi, No the dash does not need to come out. first you will open your ash tray. You will se a black metal tab push it down and the ash tray will come out. Then you will see to phillp head screws remove them. Then stick your hand where the ash tray was and pull the bottom panel it will pop out unhook the conectors. than there are 2 more philips head screws remove them and pull at the bottom of the top panel and it will also pop out.
Mar 22, 2009 | 2003 Hyundai Santa Fe
Mythos of marge - nintendo ds - the simpsons games
Mythos Of Marge: Easy completion An easy way to finish the Mythos of Marge level is to stand in the ash tray and wait for the dragon to return there. Punch it while it is inside the ash tray. You will not be harmed by the fire because there is an invisible shield in the ash tray.
info got from http://www.chaptercheats.com/cheats/ds/23996.htm
and go here to a forum where people discuss the actual level and how to play through it http://www.gamefaqs.com/boards/genmessage.php?board=939420&topic=41215448
I hope this helps
Jan 02, 2009 | EA - Electronic Arts The Simpsons Game for...
EA - Electronic Arts The Simpsons Game for DS Logo
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
