Machine wont drain, have drained it manually, now spins but still wont drain, cleaned out filter and drain pipe
  • honeymokey
    honeymokey May 11, 2010
    model number?
  • 157 Answers
Change pump
Posted on Jun 30, 2009
Indesit iwde7125
Sounds like a control board issue
Nov 04, 2017 | Kenmore 24032\24036 Top Load Washer
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Apr 20, 2008 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
