Question about Epson Stylus C86 InkJet Printer
How do you adjust the paper grippers on an Epson DX7400
  • 3 more comments
  • martin-j-hal Jun 29, 2009
    I want to know how to adjust grips or guides to get paper to feed straight
    why Am I getting answers for other machines and computers, I just want to know how to adjust grippers and guides on the Epson DX7400 so paper feeds squarely, thank you
    Obviously I'm not getting my query over - I'm getting answers to everything but what I want so I'll give up - thank you
    I ask the following question for the fifth time - My query is about the Epson DX7400 and I want to know how to adjustthe paper guides so that the paper runs square and not askew - I keep getting guides to manuals for computers or talk of c86 or something no answer to my question - please help
    Thanks for trying, but I feel I was looking for something nobody picked up
  • 2,200 Answers
Hi
There is an edge guide on the left of your printer where the paper sits which you must adjust so that it fits snugly to the edge of the paper. If you bear with me I am trying to figure a way of showing you a diagram.
Please comment if this makes sense so far.
Posted on Jun 29, 2009
  • 5 more comments
  • Radio Code Pro
    Radio Code Pro Jun 29, 2009
    Ok. Please bear with me whilst I try to post this up. The Epson model shown is different but the steps are exactly the same and this is the image Epson use to illustrate the loading paper procedure for all 7400 series printers. The most important step to ensure the paper feeds straight will be shown in step 3. May take a few moments for me to complete as I want you to have the images for your reference.
    So here are the steps involved in loading paper properly into your printer to ensure
    1) Open the paper support, then flip the feeder guard forward
  • Radio Code Pro
    2) Lower the output tray, then slide out the extension.
  • Radio Code Pro
    3) Pinch and slide the edge guide to the left out of the way.
  • Radio Code Pro
    4) Fan a stack of paper, then tap it on a flat surface to even the edges
    5) Load the paper with the printable side up against the right side of the sheet feeder, and place it behind the tabs. The printable side is often whiter or brighter than the other side
  • Radio Code Pro
    6) VERY IMPORTANT. Slide the left edge guide to the left edge of the paper, but not too tightly. Make sure it fits under the arrow inside the left edge guide.
  • Radio Code Pro
    7) Flip the feeder guard back
    You are now ready to print!
    Step 3 and Step 6 are most important to get right in order to ensure the paper feeds straight in the printing process.
  • Radio Code Pro
    Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures.
    Follow these steps and this should resolve your problem.
    Please remember to click through and rate my answer as ratings are important to the experts on this site.
    Many Thanks.
    President:
  • 1,383 Answers
There is 1 spring just set it in exact position also clean dust from paper gripper.
Then check,
Print on 6x4"
bottom tray or rear load usually has sliders to adjust for different paper size
Aug 28, 2014 | Epson CX7300/CX7400/DX7400
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
Epson dx7400 windows xp service pack 3 top line on test shows only half of the top line printing changed all the inks---took off drivers and reinstalled --- cleaned printers via maintenance epson...
Follow these steps to print a nozzle check:
  1. Turn off the Epson Stylus dX.
  2. Disconnect any connected USB cables.
  3. Load letter-size paper in the sheet feeder
Hold down the Stop button as you press the On button to turn the Epson Stylus CX back on. Hold down both buttons until the On light begins to flash, then release the buttons.Tell me the result-->Nozzle check pattern with no gaps or with gaps?
You can use this service/repair manual for Epson dx7400 ->start download.
May 10, 2011 | Computers & Internet
Have epson stylus dx7400 without cd. Want to
I have an Epson stylus DX7400 for some reason when I installed the printer language is in German. My disc is broken therefore I am unable to reinstall. What can I do?
Sep 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Install epson printer DX7400 wihtout CD
From the manufacturer's web-site:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX7400/Drivers-Support
select your Operating System and download and install the drivers.
Nov 01, 2009 | Epson Computers & Internet
Epson dx7400 printer jam
Turn off the printer and then open the scanner unit. Cancel the print job.
fon3_38.gif See Canceling Printing h018013h.gif step_2.gif Remove all of the paper inside, including any torn pieces. h018014h.gif step_3.gif Close the scanner unit and then turn on the printer. h018015h.gif
Aug 27, 2009 | Epson Stylus C86 InkJet Printer
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus dx7400
Apart from the fact this DX7400 problem is mis-filed under Epson Stylus C86, it seems probable the poster has sorted it by now!
Aug 21, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
