Question about Panasonic Lumix DMC-FZ30 Digital Camera
No power I just can't get any response from the camera. Tried recharging the battery and a new battery. Still no response
  • 4 more comments
  • Anonymous Nov 11, 2007
    same problem. here. does not want to power on anymore. batteries are full.
  • spark22 Jan 03, 2008
    nothing happens at all when I try to turn on my camera... nothing happened to it, batteries are!!
  • lewbar Feb 01, 2008
    Two fully charged batteries. Camera will not turn on.
  • JeffinMaine Jul 26, 2008
    I've got the same problem. My son was reviewing pictures on the camera, he shut if off and handed it to me. I opened the flash expecting to take indoor pictures but the camera would not turn on. I'm fairly compentent on repairs, but would appreciate the proper procedure to remove screws to view the inside. I have tried new battery and cleaning the contacts. I would wager on something coming loose inside.
  • Owen868 Mar 19, 2009
    My camara will not turn on. I recharged the battery and it tests out fine, but no power. One time I used it and set it down, the next time a couple hours later......nothing.
  • bikerider58 Apr 11, 2009
    I was taking pictures and opened the flash and the camera immediately shut down and will not turn back on. The battery had a fresh charge and I double checked it when I got home; it was charged.
    I don't see a reset button. Is this a fuse or flash overload problem?
Hi, I have the same problem with my FZ30. The camera just doesnt turn on. Even the battery when put in the charger, the light of the charger goes of in few minutes or few seconds without properly charging it. Can it be a fault of the battery or the camera itself?
Posted on Sep 23, 2008
  • 22 Answers
Same problem here too. My camera was reipaired for this same reason 2 years ago. No quarantine anymore... =(
Posted on Aug 30, 2009
I was told my Panasonic FZ 30 has a blown fuse since there is no power. Is this something I c an fix>
Posted on Sep 19, 2008
  • Panasonic Master
  • 1,689 Answers
The electrical contact inside the battery compartment may not be making contact, there may be a failure in the power control on the circuit board inside of the camera, or the switch itself is defective.
Look in to the battery compartment and see if there is anything visual to see if there is problem with the battery contacts.
You should send the camera to the service rep for an estimate.
Jerry G.
Posted on Apr 13, 2008
Why battery exhausted can not charge
This is my standard response to your type of question. It covers all the possibilities:
First, I would check your batteries. Start by removing them and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. A quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries. Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jun 16, 2014 | Nikon Coolpix S4000 Digital Camera
I cant get any response from my Intova IC12. This worked when I used it last year? When I try and charge the battery - nothing. No power. What should I do?
Hello mayairwin,
If you didn't use the camera/charge the battery for a year, then the battery may be dead. Li-ion batteries cannot be left to fully discharge. They must always have a slight charge in order to be recharged. Please contact us at Intova for customer service by email, or call us at 808-837-0074. Thanks
Feb 02, 2013 | Intova Ic12 Digital Camera
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
Camera wont power on. I tried 3 sets of batteries
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Dec 05, 2009 | Kodak Easyshare C813 Digital Camera
We have had the casio exilim 7.2 mega pixel camera for about a year - we went to switch it on and there was nothing - so i tried recharging the battery for a few hours thinking the battery was dead - and...
i think its time to change your battery ,so try switching on the camera by changing the battery .if that not works then go for hard reset method,that is, remove the batteries and leave the camera for half an hour and then insert the battery and try
Aug 06, 2008 | Cameras
Camera won't turn on.
Mine had the same problem.  I consulted and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Camera will not stay on
are you using rechargable batteries if not use them the normal batteries do not last long and to be honest are no good with digital cameras. if you are using rechargable batteries let them charge for at least 5 hours before you use them
Mar 19, 2007 | Vivitar ViviCam 4100 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
376 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
