Question about Apple PowerBook G4 17" 1.33GHz Mac Notebook
Ejecting some dvds after about 30 sec.
So..
i have different dvds and some works fine
other just pops right back out after about 30 secs..
  • Rich Elliott
    Rich Elliott May 11, 2010
    Factory discs or RW/ W disks
  • 221 Answers
The Mac can read DVDs, but not all of them: you will see supported DVDs  in the Apple menu - About this mac - More Info - Under "Hardware", select "Disc Burning". You should see the CD/DVD writing capabilities.
For my mac it's
-R, -RW, -R DL, -RW, +R, +R DL, +RW
Posted on Jun 29, 2009
Put new head gasket on a 1999 chev 4.3 now it starts but it stop right away will start
Check for a low oil pressure shut down sensor at the back of the block you might have left the wire off i know i found this problem on a Chevy pickup but the sensor was bad not sure if it was a 99 or you may have a vacuum leak. I hope this helped
Nov 09, 2011 | 1999 Chevrolet Silverado 1500
First@gmail.com, 2006 malibu cd player keeps the cd, doesn't eject or take the cd, but plays fine. Is there a part I can replace myself?
Is it a burned CD-R? I know (this is probably the same on a 2006) that on my 2005 if you put one in, it will play fine then lock the disc in. There is a fuse pannel on the passenger side on the center of the console towards the front of the car. Just pull the plastic cover off. Find the 10A fuse by the little grey box, and a blue and white circle. (or just look for the fuse labled "RADIO" on the map inside the plastic cover and then locate it in the fuse box). Turn the key off, pull the fuse, turn the key back on for a sec and the radio will not come on. turn the key off, put the fuse back in and turn the key on. the disc should either come out or you will have to push eject. This may or may not work, some people say it doesn't work for them. (this may reset the radio number buttons memory). Hope this helps!
Aug 21, 2011 | 2005 Chevrolet Malibu
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Nd 3550a will play and record cds and records movies with sonic 5.3 but will not read or play dvds in any mode. drive does not show disc in machine. Running xp dell 4600
For playing DVD's you need to install DVD softwares which is came along with the drive Or download and install the same from vendor website will resolve your problem.
Revert back for more assistance.
Feb 01, 2010 | NEC ND-3550A DVD RW Dual Layer Burner
My playstation won't eject the disc, it just beeps like there is no disc in there,
have you tried holding down the eject button for 20 sec
it should do a force eject the fan in the rear will triple in rotational speed thats how you will know if your console is even trying to do it
but turn off your console via the rear switch and then turn it back on so you see the red light
while the red light is one go ahead and hold the eject button till you hear the fans if 20 to 30 sec go by it might not work but this should solve your problem hoep i was helpful rate high~!
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Stuck DVDs
i put in a DVD yesterday and it got stuck in the machine. no mtter what i did, it wouldn't eject. it just said "No Disc". I read all the posts here and everywhere on the net. none of them worked (Stop +2-5-9), eject right after powering up. So, i called Phillips and the guy told me to unplug the machine and wait at least 5 minutes. then plug it back in, and HOLD the power button down for at least 30 seconds. after about 20 seconds it will flash some stuff on the little screen. keep holding the button. then push eject button. AND IT WORKED. the disc ejected. Now i am going to upgrade the firmware. i let the phillips guy know that they should be embarassed to have sold this unit. i am anxious to see if the firmware upgrade will fix this issue. the download for the firmware can be found at www.philips.com. search for the unit (HTS6500) under support link on top. at least i know now that i can get a disc out if its stuck.
Jun 04, 2009 | Philips HTS-6500/37 System
Phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
Feb 23, 2008 | Philips HTS-6500/37 System
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Apple PowerBook G4 17" 1.33GHz Mac Notebook Logo
260 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
