Question about Cell Phones
Jabra 46CP Bluetooth Headset w/Motorola V551 Cell Phone
I recently came across a Jabra 46CP Bluetooth Headset that my father wasn't using. I have a Motorola V551 cellphone that is bluetooth equipped however I can't seem to get the two item to sync. I couldn't find any manuals online for the 46CP as it seems to be an older model and I wondered if anyone had any ideas. Thanks for any help!
- Jon
MonsterG
  • 52 Answers
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Posted on Feb 11, 2008
how do i re-set the phone & trhe head set?
Posted on Feb 27, 2008
Bajanguru
  • 7752 Answers
SOURCE: Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
Posted on Jul 01, 2008
  • 14 Answers
SOURCE: how to sync Motorola S9 Bluetooth Stereo Headset
It is pretty easy, but I wanted my instructions to be detailed, so don't panic.
Press and hold the power button for 5 to 10 seconds until it flashes back and forth between red and blue. Then go to the settings or tools section (depending on your phone) in your phone and select bluetooth and activatre bluetooth. After that select "search" to find your bluetooth headset. When you see Motorola S9 press select it and press "pair". Your phone migh task you to enter a code which will be "0000". That's all.
Posted on Jun 28, 2009
  • 30 Answers
SOURCE: Hi, I lost the instruction
http://img1.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT8040/Documents/UM/BT8040_UM_EM_EN_1409.pdf
Here you go
Posted on Nov 19, 2010
It's charged. My phone said it was connected. Not connected. I disabled the bluetooth, and tried to "re-find" it. My cell phone can't find it
First you need to pair your bluetooth with your cellphone. Go to your cellphones manual and look on how to pair it with a bluetooth. You would need the passcode for pairing, after that then you connect your bluetooth to your phone. Sometimes it depends also on what kind of cellphone you have. Some older model of cellphones are not compatible with the newer bluetooth. Let me know if this works.
Jan 24, 2011 | Jabra Bluetooth Headset with Adjustable...
Tip
How do I pair a Bluetooth headset Jabra?
<p>Jabra is the name of a company that was acquired by GN Corporation in 2000. The acquisition of GN strengthened position as a global supplier of equipment for hands-free communication environment. The name Jabra products to raise awareness and respect for the merger of corporations. In 2005, CN created the first Jabra headset that would work with Bluetooth technology for hands-free communication. Jabra is currently considered the first and leading provider of hands-free communication. Learn to use a Bluetooth headset Jabra Bluetooth is based on having in his pocket computer. <br /> <p><br /> <p>1. Turn your Bluetooth device to your computer. <br /> <p><br /> <p>2. Click Start and select Control Panel. <br /> <p><br /> <p>3. Double-click the Bluetooth icon and go to "Setup" option. It opens a wizard. <br /> <p><br /> <p>4. Step through the wizard. He should see your Jabra Bluetooth headset in place a discovery / sending mode. You hold the button on the Jabra headset it flashes green. <br /> <p><br /> <p>5. Click "Next" when it's time to find a nearby Bluetooth device. This, then, find your Jabra headset, because it was created in the previous step. <br /> <p><br /> <p>6. Click "Next" once the devices are paired and the headset at any time. <br />
on Jun 26, 2011 | Computers & Internet
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
How can I connect jabra bluetooth to my cell phone
Generally speaking, bluetooth connects like this:
1:Turn on the bluetooth device (phone).
2: set phone to search for the bluetooth headset.
3: Turn on the headset
4: when it finds the headset (you may need to try TWICE), enter 0000 to the phone as a basic password. The two should link.
Your headset guide may specify a different password - use that.
The headset may require you to hold down a button to help the search - do what the manual says.
Apr 03, 2010 | Jabra Philips 768 / Fisio 820 / Fisio 825...
Can't get droid to pick up Jabra VBT185Z bluetooth.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Feb 05, 2010 | Jabra BT350 Bluetooth Headset Headset
Unable to pair Jabra 5050 with Motorola qa1. Bluetooth is on in both devices, unable to find device from QA1 or from BB.
Dec 14, 2009 | Jabra SP5050 Bluetooth Headset
I bought jabra bluetooth handsfree. but it not connecting with motorola l7i. so plz provide me any solution..
Dec 12, 2009 | Motorola Mobility Bluetooth Hands Free...
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
Have new Samsung Alias 2 that won't pair to my motorola car bluetooth, motorola bluetooth ear piece nor newer jabra car bluetooth. Did pair to Magellan GPS bluetooth, but voice transmission garbled. Any...
Oct 05, 2009 | Verizon Communications Samsung Alias Cell...
Cell Phones Logo
144 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
