My iPad will not hold a charge. It takes a long time to charge and than quickly loses its charge as I use it even if it is plugged in.
SOURCE: my LG Vu phone loses charge instantly the moment i
Your best luck with resolving this difficulty is with the Carrier, followed by contacting the manufacturer and/or battery retailer.
SOURCE: LG Dare quickly dying even after a long time charging.
The cells of the battery of your phone is very low that it can no longer hold charge.
All you need to do is to get a brand new battery for replacement.
Please charge the new battery with your phone to indicate the battery is full before you start using it.
This will help in a long way to keep your battery life span last long.
Take care.
SOURCE: I want to import blackberry contacts to my iPad via Bluetooth. How can I do that?
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
The following sounds complicated but it is very easy if you carefully follow the instructions.
Unfortunately, there is no cable to connect the BlackBerry and iPhone together and a user can't transfer BlackBerry contacts to iPhone directly via USB cable. So, we should export contacts out of BlackBerry and save onto a program, then import the contacts from the program to iPhone.
Things you'll need to transfer BlackBerry contacts to iPhone.
If you are the first time using Google Sync on BlackBerry. all the contacts from your blackBerry are saved to your Gmail contacts in a group called My Contacts.
Please login your Gmail and Go to "Contacts" option on the left of Gmail account.
Then you'll see a "more" menu. Click it and you'll see a drop-down menu.
Select "Export" contacts.
There are three models to export contacts out of Google account.
1. Export Group "My contacts" to Google CSV format.
Export Google contacts as csv
2. Export Group "My contacts" to Outlook CSV format. Export Google Contacts to Outlook CSV
3. Export Group "My contacts" to vCard format. So that you can import the contacts to Apple Address book or iOS devices.Such as import to iPhone, iPod touch, iPad. Export Group "My contacts" to vCard format
Now, import vCard file to iPhone
You can save the Google account contacts to computer as vCard file and download this iPhone contacts transfer program.
SOURCE: How to transfer files between iphone and ipad?
It is possible. You can sync the files to iTunes on your computer and then add the files to each device separately.
You could also add the files to your iCloud account which would sync them between both devices.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
