1996 Isuzu Trooper Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We replaced the water pump and radiator - leaking coolant
We replaced the water pump and put in a new radiator on my 1996 Trooper. It has been running good. I went in to have new tires and have them tighten up the belts. The mechanic said that my Trooper has a water pump leak. Which I have now noticed it getting hot at times. If I just replaced the water pump, where would it be leaking?
  • Anonymous Mar 20, 2014
    All the fluid drains from the radiator when the vehicle is running. It drains from the front of the engine behind a pully. I think its due to water pump failure but am not positive.
Harvey N Tawatao
Level 3:
  • Isuzu Master 3,854 Answers
  • Posted on Jun 29, 2009
Harvey N Tawatao
Isuzu Master
Level 3:
Answers
3854
Questions
0
Helped
2796753
Points
16501
It could be leaking thought the gasket or radiator hose. Remove the water pump and replace the gasket, inspect the water pump first to make sure it's not leaking through the radiator hose and weep holes, if it is leaking through the weep hole then replace the water pump again since the water pump is faulty. good luck and keep me posted.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 216 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
216
Questions
0
Helped
88541
Points
514
Recheck the gasket,reapply some RTV.make sure your thermostat is in good condition.
Marvin
Level 3:
Top Expert:
  • Isuzu Master 85,242 Answers
Marvin
Isuzu Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059531
Points
266281
THE WATERPUMP GASKET TO THE BLOCK
2000 Oldsmobile Alero losing water and running hot.
A worn water pump is the most likely. If the coolant is going down, the water is going somewhere.
The most common reasons an Oldsmobile Alero is overheating are a coolant leak (water pump, radiator, hose etc.), the radiator fan, or a failed thermostat. Coolant leak (water pump, radiator, hose etc.)
Oldsmobile Alero Overheating - RepairPal
Videos on overheating. You probably have air in the system from when you replaced the thermostat. The coolant system needs 'burping' of air.
https://www.google.com/search?q=2000+Oldsmobile+Alero+running+ho
Burping
https://www.google.com/search?q=burping+coolant+system
Running hot at highway speeds...
I would check the vanes on the water pump and the inside of the radiator. Both can cause this.
2answers
My 1999 Alero must have a leak somewhere because the thermostat gauge rises every few days. I put coolant in it at least 1 a week. I had a new water pump and thermostat put on it, but it is still...
CHECK AROUND WATER PUMP AREA.AND THERMOSTAT HOUSING FOR LEAKS.THE MECHANIC WHO PUT THE WATER PUMP ON MAY FORGOT TO PUT SEALANT ON BOTH SIDES OF THE WATER PUMP GASKET CAUSING LEAKS.LOOK AROUND THERMOSTAT HOUSING FOR LEAKING.IF THERMOSTAT SEAL WAS DAMAGE DURING INSTALLATION IT WILL CAUSE LEAKING.IF ALL LOOKS GOOD CHECK FOR COOLANT LEAKS AROUND RADIATOR .CHECK RADIATOR TOP AND BOTTOM HOSES FOR LEAKS AND CHECK HEATER PIPES AND HEATER CORES HOSES FOR LEAKS.IF ALL HOSES GOOD.CHECK FOR LEAKING CORE PLUGS.
My husband and I have mystery chronic overheating in our 96 Isuzu Trooper. The woman who sold it to us had a new radiator installed just prior to us buying the vehicle. Since then, we've installed a new...
ouch. leaking fluid and no signs of leak. check engine oil. if it appears milky, you are leaking into the cylinders. this means you'll need a new head gasket.
1helpful
2answers
1992 plymouth voyager keeps overheating, i have to put nearly a half of a bottle of 50/50 in every other day. i have no visable leaking under the car or on the engine. i have replaced the radiator,...
Sometimes the pipe that runs under the intake will leak. Can you smell antifreeze burning while you are driving? Another way to tell, is to let the vehicle run with the cap off. IF you get alot of bubbles out of the radiator, you have a cracked head, or a bad head gasket which is also a fairly common problem. It will push the antifreeze out of the radiator, and cause it to overheat.
2answers
Coolant leaking
the leak may be a water pump. the fan only comes on when the ac is used or the temp passes a pre determined number. so with no ac the fan will run once in a while....not always......
5helpful
2answers
Trooper Overheating
Your radiator efficiency has been reduced by (what is called) blossoming. Blossoming is electrolytic growth of crystals inside radiator duct passages. This typically occurs in the older Troops as gradual overheating probs cause the vehicle to run low on coolant, then water is being used to top off system repeatedly, acid levels in cooling system rise as the coolant protectants degrade and the inside of the radiator ducts 'blossom' with small crystalline growths that reduce the radiators flow and ability to cool the engine. Flushing and blowing out the radiator are temporary fixes. Replacing the radiator is the permanent fix. You did the right thing by replacing the water pump, tstat and radiator cap. An old, original water pump usually fails soon after the radiator is replaced. New Trooper radiators are fairly cheap, $85+. The replacement can be done by any backyard mechanic or DIYer in under and hour. You know the typical warnings about the toxicity of antifreeze and the deadly affects on pets who drink improperly disposed coolant. Good luck to you. It's an easy remove and replace. Your Trooper will thank you with many cool running miles. -Geoff
1helpful
My radiator (1996 Ford Explorer) is leaking at the bottom. No problem with heating or cooling or running hot. Just steady drip
You can have it repaired at a radiator shop, or replaced with a new one. Are you sure it's the radiator that's leaking, sometimes it's the water pump or a hose that drips down onto the radiator. It can be difficult to locate due to air circulation of the fan and driving which spreads the leaking fluid around. I assume u top off the coolant often, since u say there are no issues w/ it overheating or running hot. If this is the case, the leak will eventually get worse, and adding coolant constantly gets expensive. Good luck, let me know what u decide to do, or if u have any other questions. Curt
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
