Question about Sony STR-DE310
Receiver won't turn on
The receiver started tripping while on but would turn back on and be fine, even at low volume. Which leads me to a power issue, now the receiver won't turn on at all even on a different curcuit. I checked all speaker cables and they seem ok.
  • poybenp Jul 01, 2009
    The fuse is a cylinder fuse and looks white instead of clear. How can I tell if it is bad?
  • Rich Elliott
    Rich Elliott May 11, 2010
    What is the age of receiver?
    President:
  • Sony Master
  • 1,114 Answers
Disconnect all the speaker wires, then turn the unit on. If it does not power on and the standby light is "out" pop the top and check the internal fuse by the power cord. Beyond that, without the proper testing equipment, it's all a guess. If the unit turns back on with all the wires disconnected, then reconnect your speaker wires one by one and test each time. If it does not cut out, you found the problem. Wire touching. If it cuts out, disconnect wire at the speaker and re test, if it still cuts out, replace the wire and try again. Then re connect the same speaker to the new wire and test. If your lucky, all will be well. If not, it will need to be serviced or replaced, based on cost. Hope this helps
Posted on Jul 01, 2009
1990 Volkswagon Jetta won't turn back on after long drive.
Then you have a start up problem and it reside with the cold start valve,The cold start valve operates even if the vehicle is warmed up,the cold start valve can be plugged up,or even have a bad connection,The cold start valve operates by a thermotime switch.This switch located on the near bottom of the radiator may have gone bad or disconnected,Here is the easy cost effective route, replace them both,it will cost more to trouble shoot it than just replace it.
Aug 07, 2012 | 1990 Volkswagen Jetta
I own a RX-V1065 AV receiver. Whenever I turn the volume above a certain low volume level the receiver powers off. I can than turn it back on and continue watching my theater at a low volume. Anything...
If this just started happening I'd look for loose speaker wires or...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 08, 2011 | Yamaha Audio Players & Recorders
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
I JUST REPLACED MY OLD RECEIVER WITH A YAMAHA AND DON'T SEE WHERE TO CONNECT THE POWER FOR THE CD AND TAPE PLAYER. DO I PLUG THEM INTO A POWER STRIP?
Yes, that will be fine just make sure its the same AC power as the new Yamaha is using.
Before connecting any AC mains always turn off your Amp, and don't turn back on again until all the signal cables for the new equipment are connected.
When checking if it all works, always start with low volume to check everything is correct.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Yamaha RX-V663 Receiver
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
May 03, 2010 | Garmin nuvi 650 GPS Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
My unit keeps shorting out. wondering if its my car or the unit?
I would hazard to guess that you are running a speaker "ohm load" that is less than 4 ohms per channel. Or 8 ohms if you are running in bridged mode. You should NEVER blow a fuse. Re-check all your connections. Your "cutting out when the headlights are on" problem is due to low battery voltage to the amp. Use bigger wire on both your +12 lead and your ground lead. Make sure your battery to chassis ground lead is even bigger than your amps power lead. Make sure your amps ground lead is big, beefy, and short. And get a boost capacitor. When you have a huge amp in the trunk, you must treat it as if you are trying to run your engine starter from the trunk when it comes to the size of your hot wire and ground wire. Good luck.
Nov 26, 2008 | Pioneer DEH-P4000UB CD Player
Power problem?
1. Is the head unit powering the speakers directly or through an amp?
2. What ohm load (4,8,) per channel and how many speakers?
3. Does it do it with the bass set all the way down?
If you have access to a voltmeter see what the voltage is on the yellow and black wires when it is diming. It should be stable ~ 13.5v with car on. if its < 10v when dimming either there is:
1. Shorted speaker lead.
2. Bad ground to radio.
3. loose power feed to radio.
4. Ohm load below 4 ohms, causing the eccess current draw.
May 15, 2008 | Pioneer DEH-P4500MP CD Player
Kenwood KDC-MP228
Your ground is weak or your running your radio at low voltage. Good Luck
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Your speakers are way tp powerful you should only use speakers just over what the amp is rated at the most and check your impedance is not lower then 6 ohms and turn the bass to half way i am using 60 watt bookcase psb speakers and they work just fine and they pound no problem
Aug 24, 2007 | Technics SA-AX730 Receiver
Sony STR-DE310 Logo
177 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
