Question about Sony STR-DG500 Receiver
Sony STR-dg500 going into protect mode.
I turned on my receiver and after a minute or so it went into protect mode and turned off, reading the sony users manual it said to check your speaker connections and do a memory reset, i have done both to no avail.
I opened the receiver up and saw no visible signs of electronics failure, and i would like to know what component is most likely to need replacing so i can try that before i purchase the service manual.
SOURCE: SONY STR-DE675 RECEIVER
Protect mean that the speaker wires are touching eachother or that one of your speakers are blown and it is shorting out the receiver.
Posted on Dec 24, 2007
  • 319 Answers
SOURCE: Protector mode..
I own this model and found if powered from an isolation transformer type surge protector, with other equipment, this may cause insufficient line voltage to unit. Try plugging directly into wall socket, if that was the case. Otherwise, protect indicates problem with circuit, take to prof. tech for check out.
Posted on Apr 13, 2008
  • 35 Answers
SOURCE: no sound out of my
Were you playing it at a high volume when it quit playing?
Posted on Nov 21, 2008
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
  • 88 Answers
SOURCE: My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Posted on Aug 29, 2009
PROTECT MODE
usually means a short in the amp section. Needs to be repaired before it will turn on properly
Nov 17, 2013 | Sony STR-DG500 Receiver
"protection", no sound. What happened?
Usually means there is a short in the amp. Would have to go in for repair.
Jan 17, 2013 | Sony Str Dg500 Stereo Receiver Digital...
On my sony STR-DG500 Receiver only the video 2 output works for video. I can hear all aother modes but no picture. Any guesses?
Double check all of your connections and settings on the receiver. You might also try resetting the receiver.
Aug 02, 2012 | Sony STR-DG500 Receiver
Sony receiver says protect
Please see the link below for an explanation of protect mode. For your specific unit, the problem is most likely shorted output transistors. Expect a parts cost in the $40 range.
Please update this if you have any further questions.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Feb 11, 2011 | Sony STR-DG500 Receiver
Aug 29, 2009 | Sony STR-DG500 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Sony "Protection" mode - STR-DE725
My sony used to do that to umm cant remember the model but yeh i could play it at low volume but as soon as i turned it up it would start clicking and telling me to turn of the power...
I resolved it by checking every cord connected to it, it turned out that because I connected two speaker cables together i didnt seal it properly and they were touching this was making it go into protetion mode.
Nov 25, 2007 | Sony STR-DE725
Lock up
It probably is but may require a service person to physically open the unit up and do some testing/repair work which can be expensive if you dont know somebody or have the skills yourself.
Nov 08, 2007 | Sony STR-DG500 System
Sony STR-DG500 Receiver Logo
977 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
