Question about Dometic RM2852 Refrigerator
Will not stay lit
The fridge will light on propane every time but wiil only run about thirty seconds and shut off
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Posted on Jul 09, 2009
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Model 7732 serial # B-92114 80-11 new 3308741.002 board 6/201 new 46-0452 thermocouple...
THESE USE SUCH A SMALL AMOUNT OF GAS ITS CRAZY... I REMEMBER STARTING MINE, MY FINGERS WOULD HURT SO BAD AFTER WAITING FOR IT TO GET GOOD FRESH GAS UPTO THE PILOT LIGHT TO STAY LIT.. THE ONLY THING YOU CAN DO IS BLEED THE LINE OF AIR AT THE FRIDGE. OR SIT THERE FOR ABOUT 10 MINUTES HOLDING THE START BUTTON.. YOU WILL SEE THE FLAME TURN FOM A KINDA WHITE TO THAT BRIGHT BLUE COLOR . THAT IT ! THAN IT WILL STAY LIT .. IF NOT THAN YOU WANT TO MAKE SURE THE BULB IS IN THE FLAMES PATH. I HOPE THIS WORKS FOR YA.. CUZ PARTS CAN BE KINDA HARD TO FIND, AND THERE NOT FUN TO WORK ON .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 24, 2011 | Refrigerators
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Gas shuts off after 30 seconds
first try fitting a new thermocouple,its the short 1"stick that keeps the pilot lit....
Jun 02, 2010 | Dometic RM2620 Refrigerator
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Jul 26, 2009 | Dometic RM2652 Refrigerator
Propane furnace won't stay lit pressure out is 9.3 would this be the problem
when does it shut off about three seconds after lighting if so clean the flame sensor it could have carboned up
Apr 28, 2009 | Goodman GMS90703BXA Heater
Dometic RM2852 Refrigerator Logo
688 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
