Washer wont stop filling even when its washing. GE
Washer wont stop filling even when its washing. I unplug it and it still fills . Only way to stop is turn the water off.
GE WBSE312082WW LF184028G
  • Anonymous Mar 25, 2014
    My nautilus dish washer won't stop filling and do a wash can any one help me cheers
    President:
  • 3,113 Answers
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Posted on Jun 29, 2009
Washer wont quit filling even when turned off
If you unplug it and it wont stop, the valve is jammed open with debris etc. It should be replaced. If it stops filling when you unplug the power, there is something wrong with the control board and it is still sending power to the valve even when off.
Feb 19, 2016 | Washing Machines
GE washer wont stop filling with water
If your timer dial doesn't advance and it just keeps filling sounds like a bad timer.
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Washing machine wont stop filling with water even on small load it floods my floor
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Apr 20, 2011 | GE Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
My GE washer wont stop filling in any cycle. Even if you pull out the plug. Leaks everywhere. I blew into water level switch hose and it clicks. Model number WBXR1060T. Thank you
If water continues to fill and you have unplugged the washer from the wall then your fill valve is stuck open and needs to be replaced. Turning off the water at the wall faucet should stop the water. The fill valve is what the hoses are attached to at the washer.
Feb 02, 2010 | Washing Machines
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
HELP
ww.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
http://www.managemyhome.com/mmh/Troubleshooting_Guides/TopLoadWasher.pdf
Nov 16, 2009 | Washing Machines
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Open Questions:
Washing Machines Logo
355 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
