Question about Char-Broil Grilling
My Charbroil grill igniter won't work. Have to
My Charbroil grill igniter won't work. There's no clicking noise anymore when the igniter button is pressed. Have to stick long lighter in to light grill. What should I do?
I';m sure everyone thinks they are giving good advice, but READ THE SYMPTOMS. The guy says his ignitor doesn't "click" anymore. And most of you tell him he needs a new gas regulator. Fix his problem, don't create new ones. He needs his ignitor fixed. Maybe just a new battery? Or maybe the whole ignitor unit But certainly not a new regulator, etc, etc.
Posted on Aug 24, 2013
  • 10 Answers
SOURCE: Charbroil gas grill will not ignite... needs repai...
may just need new battery in the button
Posted on May 01, 2010
  • 4736 Answers
SOURCE: I have a Kenmore Quantum
The problem you're having is related to the OPD Valve in the Propane Tank. But, it is solvable by following the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Posted on Aug 09, 2011
bulldogchief
  • 388 Answers
SOURCE: Propane grill wont ignite
Well, it sounds like your grill is experiencing vapor lock. Vapor lock is basically air caught in the gas line and there is a relatively easy method to fix this. I want you to try this method and tell me what you get, ok? First, open the tank's valve, then open the burner valve and light the grill. Immediately after you see a blue flame, turn off the tank's valve, count to five and then close the burner valve. Repeat this procedure three times, the problem should clear itself.
If you are still experiencing problems, the regulator may be faulty and needs to be tested next, so go get a new regulator from your Lowe's and run the procedure again. If after all this, you are still experiencing the problem, let me know here. Good luck!
Posted on Jan 07, 2010
CRTN
  • 716 Answers
SOURCE: The one click starter doesn't work anymore.
Click Here. You Can Just Buy A New Igniter From Ebay And Replace The Whole Assembly.
Sincerely,
Michael Scott
Posted on Mar 24, 2009
  • 60 Answers
SOURCE: Dynasty Gas Grill automatic lighter buttons not working
i dont know how old your grill is ut it most likely has batteries that need to be replaced
Posted on Aug 20, 2009
How do i chane the ignition button on the gas grill
Contact manufacturer for new igniter, new igniter should come with instructions for replacement. It should be fairly simple, disconnect two wires and retaining nut and then replace with new igniter, connect wires and screw on retaining nut.
Apr 26, 2014 | Char-Broil CharBroil 4637318 Grill
How do I take off the ignition button from the front of my char broil red gas grill to change the battery?
It is not necessary to remove the whole ignition module. Just unscrew the plastic ring around the rubber push button. The battery holder is inside that. Be sure to install the new battery facing the same way the old one is.While the old one is out, check the contacts inside the battery holder for corrosion. If you see any, a Q-Tip and WD40 work well to clean it OFF.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 27, 2011 | Char-Broil CharBroil 4637318 Grill
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need a new ignition swicth. year 2005 model DHLB
Whether it's electronic ignition or the old, standard, push button piezo ignitor, you can find it at the Char-Broil Parts Link below.
Happy Grilling!!
May 20, 2011 | Char-Broil Commercial Stainless Steel...
Can not light flame
Gas is on. Look to see if the magneto is working properly. Do you see a spark when you press the ignition button? Perhaps the magneto gap is too much or the gas is not in contact with the spark.
Aug 16, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
Cannot get ignition
http://www.charbroil.com/Consumer/ConsumerCreateCase.aspx
go to this link, fill in the info requested and a charbroil engineer will solve your problem for u. enjoy your grill. they are great when they work.
Nov 10, 2008 | Thermos Grill2Go Fire+Ice
New Braunfels Bandera Smoker model#08201345
This brand is made by CharBroil. Click on the Customer Support link to register:
http://www.charbroil.com/Consumer/default.aspx
May 31, 2008 | Grilling
Grilling Logo
1,536 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
