Question about Plumbing
Sulfur smell from the Delta faucet sprayer. Every morning, or when we have not used the spray for a while, there is a hydrogen sulfide smell that comes when we use the spray. We have tried starting flow via the hose only with the sprayer removed. The smell comes from the hose or faucet mechanism. We do not experience odor from the water out the top of the faucet. What could be the problem?
  • 1 more comment
  • John Ward
    John Ward Jul 22, 2009
    No, there is no water softener in the system. I have had water softeners before, but at another house.
    The previous kitchen faucet was Peerless, I think. We replaced it with a newer unit. This unit is otherwise just like the one removed.
    When the flow is started through the sprayer only, there is this sulfur smell until it has flushed. I have opened the top valve mechanism, but have not lifted out the diverter valve. I see no items that are corroding or which could be a source for sulfur-like smell.
    I have removed the spray head and flowed water via the hose to see if there was maybe something in the hose. I find nothing.
    The only guess might be that the hose itself is exuding some smelly material. One would think that if that were so, eventually the source would run out and quit giving off the odor.
    Big mystery!
  • John Ward
    Jul 22, 2009 - No, there is no water softener in the system. I have had water softeners before, but at another house. The previous kitchen faucet was Peerless, I think. We replaced it with a newer unit. This unit is otherwise just like the one removed. When the flow is started through the sprayer only, there is this sulfur smell until it has flushed. I have opened the top valve mechanism, but have not lifted out the diverter valve. I see no items that are corroding or which could be a source for sulfur-like smell. I have removed the spray head and flowed water via the hose to see if there was maybe something in the hose. I find nothing. The only guess might be that the hose itself is exuding some smelly material. One would think that if that were so, eventually the source would run out and quit giving off the odor. Big mystery!
  • Bill Johnson May 11, 2010
    do you have a water softener system installed?
  • 175 Answers
Your incoming water from the well is contamiated. A delta faucet will combine oxygen with the water and make the sulfer smell come out. It could also be iron bacteria causing the smell. Look in the back of your toilet tank and see if your have reddish or black stringy algae looking stuff growing in there. If you do, you have iron bacteria and it will smell.
Posted on Nov 20, 2009
  • 117 Answers
Maybe something funky is growing in the hose, try replacing it! call delta they will probably send you one for free! just tell them it's broken
Posted on Aug 01, 2009
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Jun 08, 2014 | Delta Faucet Delta 470-BL-DST Signature...
Our Maytag washer emit a rotten egg smell and the wet clothes also come out with this smell. What is causing this and how do we fix this issue?
Sounds like a sulfur-eating bacteria, you're smelling hydrogen sulfide. Are you on city water or do you have a well? Sulfur-eating bacteria can live in a well (as can iron-eating bacteria) and it might find a happy home in a washing machine too.
Since they live in an acidic environment (the hydrogen sulfide, dissolved in water, makes an acid) I would try a caustic first- bleach would be a good first bet.
If you have a well and the bacteria came from it then it'll come back. Consult with a local well drilling operation, they can tell you if you have bacteria in your well and how to deal with it in a locally acceptable fashion.
lp
Dec 29, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Just rented a home in the country the water smells like rotten eggs
Hydrogen Sulfide Gas can occur in wells, and gives the water a characteristic "rotten egg" taste or odor.
  • Install an activated carbon filter. This option is only effective for low hydrogen sulfide levels, The gas is trapped by the carbon filter is saturated.
  • Install an oxidizing filter, such as a "manganese greensand" filter. Manganese greensand filters are often used to treat iron problems in water. The device consists of manganese greensand media, which is sand coated with manganese dioxide. The hydrogen sulfide gas in the water is changed to tiny particles of sulfur as it passes through the filter. The filter must be periodically regenerated, using potassium permanganate, before the capacity of the greensand is exhausted.
  • Install an oxidation-filtration system. These systems utilize a chemical feed pump to inject an oxidizing chemical, such as chlorine, into the water supply line prior to a storage or mixing tank. When sufficient contact time is allowed, the oxidizing chemical changes the hydrogen sulfide to sulfur, which is then removed by a particulate filter, such as a manganese greensand filter.
  • Aug 08, 2010 | Whirlpool Water Heaters
    Delta side spray replacement
    Delta makes sprayers to match the faucet design. Functionally they're about all the same. GO to theirr web site: http://www.deltafaucet.com/customersupport/index.html
    If you don't know your model number you can use their wizzard and identify your faucet model. Then go to the parts section. One difference on the number you listed is I believe on comes with the mounting fitting that attaches to the sink. Some don't have it if they go through the faucet base itself.
    Delta faucets have lifetime guarantee, I'm not sure if that includes the sprayer. (I doubt it)
    Jul 11, 2010 | Delta Faucet Plumbing
    Delta single handle pull-out sprayer loose from base. How to tighten it?
    Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
    It designed to be tighten by hand to avoid damaging.
    May 19, 2010 | Delta Faucet 470-DST Signature Diamond...
    Delta Faucet (Series 2467) Sprayer doesn't work
    Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
    Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
    I have a 2002 Chevy Tracker with a sulfur smell. It passed the e test and has no engine codes. It is worse climbing hills but has no power loss.
    Hydrogen sulfide in the exhaust, which is produced by trace amounts of sulfur in gasoline. It's supposed to be converted to sulfur dioxide in your catalytic converter.
    This may be indicative of a fuel-injection problem, and can be cured by a sharp mechanic.
    But often it means a failed catalytic converter.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 18, 2009 | 2002 Rolls Royce Rolls Royce Silver Spur
    Sprayer loosing presure
    If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
    Here are the instructions:
    1. Turn off water to faucet.
    2. Remove handle.
    3. Remove top cap.
    4. Turning spout back and forth gently lift and remove.
    5. Remove and replace diverter.
    Hope this helps and please remember to rate this!
    Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
    Delta kitchen faucet mixed spray...diverter problem???
    No a pull out sprayer problem is different.
    First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
    In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
    Delta Faucets
    If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
    Hope this helps and please rate this!
    Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
    Faucet/sprayer coordination
    If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
    2. Remove handle.
    3. Remove top cap.
    Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
    Plumbing Logo
    1,004 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
