Question about Motorola Mobility RAZR V3
Cellphone freeze
I have a motorola razor and the on anf off are working, the problem is i just heard the volume is showing in the screen and all the keypads are not working, my cellphone is not now under warranty, i can still answer if someone calling but i cant call or using any keypad,i dont know what to do,i have some important pics and videos with my babies and now they said the cellphone freeze, what should i do?
    An expert whose answer gotĀ voted for 100 times.
  • 111 Answers
Re: cellphone freeze
One thing to do is loosen the screw on front screen near the volume buttons..remove the small rubber circles first so you can see the screw..
Posted on Jan 28, 2008
0 characters
3 Points
Just a m on the screen. cant turn on or off
hi kbfinne take the back off first and then next you want to take the battery out. tHIS SHOULF TURN YOUT PHONE BACK ON FOR YOU. If this doesn't help you can do a hard reset on your phone. hold the power button anf the volume key at the same time you will see a boot up screen. Warning fon't fo the hard reset unless you have everything back up on your phone. ok pulling the battery show get the phone back on.
Mar 09, 2011 | Motorola Mobility DROID 2 Cell Phone
Blank screen, flashing keyboard, confusion
My Motorola Razor cellphone all of a sudden went blank, i took out the battery and put it back in and turned it on, but the keyboard just flashes and the screen stays blank, what do i do?
Jul 27, 2009 | Motorola Mobility RAZR V3
Verizon razr v3m freeze
That is a software issue. You need to either contact motorola or verizon regarding that issue. This is a known problem with their phone and they never fully resolved the first batch of the Razor freezing issue.
Sep 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Downloading pictures on my computer off of my motorola razor cellphone
activate gprs n open images in web then copy the inages are save whloe web page.
ur's kishore chowdary.
May 04, 2008 | Motorola Mobility RAZR V3
my phone is the same i have a motorola razor and everytime i go to type a message it freezes HELP
Apr 26, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razor V3 Lime Green
this is a very simple problem to fix just take it to a mobile service center and have them correct the issue for you.
Mar 06, 2008 | Motorola Mobility RAZR V3
i have the v3i and it had the same problem its usely the flex cable that messes up if its opend some times fast the screen gos white if you change the flex that should solve your problem . cumputer tech
Nov 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My screen is black
RAZORS JUST ****! Get any phone but a razor!!!
Oct 21, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Razr V3M's external display not showing wallpaper. iTunes help too!!??
As far as I know only razr v3i has i tunes. as far as the external display not showing your wallpaper as the internal screen i'm not sure except if it dosen't show the time and stuff on the external display your screen's connector for your display may be loose if so thier should be a solved problem for that.
Mar 12, 2007 | Motorola Mobility RAZR V3
Razr phone freezes up
Its common with motos razors to get freeze ups. I even heard about it happening when sending sms or working on the calendar. If you think it might be the humidity, you could try putting it in an airing cupboard for a few days, with bat disconnected. If nothing works, try getting it fixed on warranty if valid, just don't mention the humidity part ;] good luck
May 03, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
