Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Red started to print yellow and now I have lines of black text missing
  • 375 Answers
It is dirty - run it through the cleaning cycle. Also, check how much ink is remaining.
Posted on Jun 29, 2009
2 Suggested Answers
EMSRSERVICEG
  • 426 Answers
SOURCE: I keep getting red lines and missing colours when
remove the ink clean the ports for the ink then put them back
Posted on Jan 13, 2010
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
Black ink will NOT work! NEW cartridge!!!
Your print head is already clog, if you can find chemical solution in your area,you can try to soak it without removing the print-head, on its parking put some solution then let it be there for 24 hrs then try printing,do this for three days if nothing happens,buy a new printer, because buying a print head is not practical, it almost cost the same as a new one.
Sep 18, 2009 | Brother MFC 420CN All-In-One InkJet...
Incorect line of colour from one edge to the other
I am presuming the rest of the page prints the correct colour and this is an area in the direction of feed that is missing yellow. Try swapping the yellow and magenta drum positions and then the green text should come out a very dark blue colour. if it does then the fault is with the YELLOW drum, if there is still a noticeable Cyan stripe still then the fault will be with the LED head or engine control board.
Apr 21, 2009 | OKI C5100n Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Red text and lines appear in Black text
The red line is indicating a HYPERLINK to the email address of the user name, or other linked text in the Email.
If you are printing a program, you will not be printing anything with a hyperlink, so that should not be an issue.
Apr 27, 2008 | HP PhotoSmart 7660 InkJet Printer
Canon i455 not printing properly
(i posted this for someone before)
When you remove the black cartridge there will be electrical contacts inside the printer that lines up with some contacts on your cartridge, make sure these are clean
Also, according to this printers manual, have you tried a printer head align?
"(1) Open the Printer Properties dialog box. See Opening the Printer Properties dialog box directly from the Start menu
(2) Click the Maintenance tab.
(3) Click Print Head Alignment.
Follow the instructions on the screen."
Oct 31, 2007 | Canon i455 InkJet Photo Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
